using 110 octane
  • Thread starter Thread starter bowtietrader
  • Start date Start date Aug 31, 2004
bowtietrader
68
  • Aug 31, 2004
do you think this would help at all?? im going to be spraying 150 shot
BlackFox5.0
3,514
Massachusetts
Aug 31, 2004
  • Aug 31, 2004
Run 93 and back down timing if you have to. I would use it. I have never run nitrous so i don't know much about it, but I think your better off with the cheap stuff.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 31, 2004
  • Aug 31, 2004
It would allow you to run more timing with less chance of detonation -- which of course you don't want with nitrous.
bowtietrader
68
  • Aug 31, 2004
with a 150 shot (GT-40 plate system) what should i set my timing at?? with 110??
Rick 91GT
Mustang Master
95
99
PA
Aug 31, 2004
  • Aug 31, 2004
What's the entire combo? If you do not need the high octane gas do not use it, it burns colder. I also assume you are talking CAM2 which is LEADED, not good for the stock O2's.
RydeOn
Licensed to Chill
6,273
orange county, CA
Aug 31, 2004
  • Aug 31, 2004
Lol, me and my freinds were just having a discussion about this on Sunday. Friend #1 (a honda service writer) was telling me that high octane gas ruins your 02s but adds power. I didnt believe him until Rick said anything. Friend #2 said that the engine runs much smoother. Friend #2 is a honda dirtbike rider and a honda tech, but doesnt have a souped up car. I was trying to tell them both that high octane doesnt add power by running it. You need to increase timing to get a power increase. But I dont know anything about the engine running smoother, cuz I never tried it.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 31, 2004
  • Aug 31, 2004
Rick's right - it should only be used if the gains from timing increases/compression increases/NO2 use outweigh the downsides of it being harder to ignite and burning colder/more slowly. And I didn't even think about how they were increasing the octane - lead causes all sorts of problems. Do they make anything with that high octane that's unleaded?
The Shape
2,224
East ARKANSAS Delta
Aug 31, 2004
  • Aug 31, 2004
Baccardi
D
Daggar
3,902
  • Aug 31, 2004
Yes. Many Sunoco stations (I've not seen them here in Illinois but several in Delaware) sell 103 Octane, no lead race fuel. The rice rocket motorcycle guys fill up their tanks with the stuff thinking that it gives them more power. Who am I to tell em they're pissin' in the wind? hehe
Rick 91GT
Mustang Master
95
99
PA
Aug 31, 2004
#10
  • Aug 31, 2004
  • #10
I don't consider the 103 HIGH OCTANE.
Micheal, Sunoco (GT104 actual motor octane around 99), VP (C10 motor octane around 99-100) and Torco make a UNLEADED race fuel but be prepared for $6.00/gal or more. The readings on the Sunoco are all over the place according to the info I have seen. The NMRA took it off the Spec fuel list and re-added the VP.
Most guys that try to run a LEADED fuel like C16, CAM2, etc.. only get a few thousand miles out of the O2 max before they fail...
EVERY COMBO IS DIFFERENT but on my old built 302 combo, 8.8:1 comp I ran 93 octane pump gas, 8 degrees base timing, 1 range colder plus gapped down to .035 and ran 130mph.
SUMMER GAS is different then WINTERIZED gas you need to be very careful it changes the tune and can caused burn't pistons!
88GTtom
198
Woodbridge NJ
Aug 31, 2004
#11
  • Aug 31, 2004
  • #11
i remember when i owned my 87 turbo buick, everyone was making their own homemade fuel using a paint thinner called xylene. it is equal to 117 octane. one gallon of xylene and 3 gallons of 93 give you 99 octane. No more than 30% xylene mix. Add 0.5 ounze of Marvel Mystery Oil per gallon of xylene. It will not hurt your injectors, it will clean them. if anyone has any doubts go to turbobuick.com and do a search on the word xylene. later, tom
R
RickyB
592
NJ
Aug 31, 2004
#12
  • Aug 31, 2004
  • #12
ive only seen CAM2 unleaded 100 octane....never seen leaded at any pump
Rick 91GT
Mustang Master
95
99
PA
Aug 31, 2004
#13
  • Aug 31, 2004
  • #13
I can asure you that CAM2 is 110 octane and it is LEADED, under $4.00gal and is a old scholl fuel that has been around for years. They sell it 2 blocks up the street from me at Sunoco.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Sep 1, 2004
#14
  • Sep 1, 2004
  • #14
Shape - "Baccardi" - nicely lobbed in there.....
Paint and Body Cowl Pan
  • jeremyzcook82
  • Sep 13, 2026
Fox 5.0 Mustang Tech Oct 3, 2026
Rcdgl
R
G
Octane on the 5.0 Coyote
  • gray owl
  • May 17, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Bullitt347
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
