Efi to car pcv HELP !
rgrendell
Connecticut
I purchased an 89 town car efi engine as a cheap replacement for a 73 carbureted engine that plugged the sump and ate its rod bearings . Im swapping from efi to carb intake but the pcv passage at the back of the valley is exposed when the carb intake is installed. Im sure if it were left open it would pose a vaccum leak or an oil spraying mess . Any ideas ? Thanks for your help !
Are you saying, at the back of the intake that you have, is open so that the stock provision of the PVC valve on those engines is exposed? You’re going to have to get a different intake that has a provision that covers that spot or you’re going to have to create a PVC system that uses that intake, provision and route that intake occurs to a nipple on your new manifold. As @AeroCoupe suggest suggested, post some pictures of your set up so that we have a better idea with the issue is good luck.
The only thing I can think is this hole that is supposed to have a freeze plug in it but for it to be exposed you literally cannot have the correct intake on it.
Reactions: Mcmahst
Oh I know what I posted but that’s the only hole I could think of when the OP said “but the pcv passage at the back of the valley is exposed when the carb intake is installed”.
OP needs to post a photo
The hole should be plugged at the top with a small freeze plug
I believe some of those plugs are not completely covered by the intake manifold when installed
My 69 has a Roush manifold on it, and I think mine is not covered completely
