v3 vortech alignment issues?
  • Thread starter Thread starter allballsmustang
  • Start date Start date Aug 3, 2010
allballsmustang
174
Lehigh Valley, PA
Aug 3, 2010
  • Aug 3, 2010
Anyone install a v3 vortech setup on a 87-93 fox? I'm having alignment issues on the serpentine setup and some of the directions seem a little vague from Vortech. My issue lies somewhere with the tensioner and the a/c idler. Any help would be appreciated. Thanks
Jim
Cobra912
1,777
11
39
Wish I was anywhere but here
Aug 3, 2010
  • Aug 3, 2010
what kind of alignment issue? need pics
allballsmustang
174
Lehigh Valley, PA
Aug 3, 2010
  • Aug 3, 2010
well it seems like the belt rides towards the front of the tensioner even though the tensioner and the ac eliminator are aligned
allballsmustang
174
Lehigh Valley, PA
Aug 3, 2010
  • Aug 3, 2010
im wondering if the brackets are shimmed properly because the vortech directions say washers may be necessary... if i could find someone that has a v3 with close up pics that would help a lot
I
izak
29
  • Aug 3, 2010
Pics, pics, pics, even cell phone pics. I just did mine and trust me I hit everyone up on here. lots of help. Ive been helped and dont mind helping but It helps if we had pics.
9
91foxbod50
486
  • Aug 3, 2010
You need to put washers on the bracker for the unit. Had the same problem with the novi i was running. Go to the depot and pick some up.
1993SSP
1,194
Ky
Aug 3, 2010
  • Aug 3, 2010
I had issues with my vortech setup too, I ended up having to use washers and a longer bolt on the supercharger tensioner pulley. I also had to place 1 washer on the main tensioner bracket as well where it bolted to the bolt that runs thru the water pump. Just takes some time to get it lined up right.
mineralgsvt
583
Carmel, IN
Aug 6, 2010
  • Aug 6, 2010
I had problems also.. I think I started with 2 washers (shredded a belt) then removed 1.
No issues since.
Pics would help...
allballsmustang
174
Lehigh Valley, PA
Aug 7, 2010
  • Aug 7, 2010
i got a laser aligntment tool, im going to work on it this weekend. If I can't figure it out ill post pics. I also spoke to Vortech again and from speaking to them I believe I may need to remove a washer also. Thanks
Rick 91GT
Mustang Master
95
99
PA
Aug 8, 2010
#10
  • Aug 8, 2010
  • #10
I use a laser alignment tool when I put superchargers on sepertine or cog (even more important with a cog set-up), or delete accessories. You would be surprised how off things can be just do to stacked tolerances. Sounds liek your on the right track, if you still fight it let us know....
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
C
Vortech water pump and tensioner pulley issue
  • Crooner88
  • Feb 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2025
revhead347
D
2006 Roush Stage 2 Mustang Chin Spoiler/Lower Grill Inserts Needed
  • DG_Damn_Good
  • Oct 13, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 14, 2026
DG_Damn_Good
D
