vaccum line ?
  • Thread starter Thread starter dresmnkaos
  • Start date Start date May 25, 2008
D
dresmnkaos
100
  • May 25, 2008
working on a 93 5.0 lx with no ac, smog, or cruise cont.
im stuck on the TAD/TAB and the other component around the passenger side strut tower. how do i reroute the vaccum lines to bypass all that stuff.
4G-KDMP
935
CA
May 25, 2008
  • May 25, 2008
You shouldn't need to reroute those vacuum line if your removing / bypass those parts just remove the lines and make sure the other need is capped off. your check engine light will probably come on after you do this.
D
dresmnkaos
100
  • May 26, 2008
yeah i knew if you just remove them it would throw a CEL, thats fine with me for now. im gonna geta chip to remove that later on. what im wondering do i have to cap the line coming of the back of the intake and the line coming of the EGR/ if you need pics. of what im talking about the ill be glad to post some to clearify?
also what can i do to to make the computer not throw these codes?
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
May 26, 2008
  • May 26, 2008
if you remove the EGR vaccum like or any vac line for that matter from the back of the intake you nedd to cap it off, or else you will have a vac leak.
you can but some little black caps at the parts store.
as for the codes the correct way to get rid of them is to have them tuned out via a custom chip or other tuning method. the redneck way is to cut the CEL wires to the bulb but i wouldnt suggest doing that.
93 LX
3,081
Norwalk, CA.
May 26, 2008
  • May 26, 2008
jrichker has a fix for this but I cant find it on the site. Calling Stangnets best tool! ;o)
D
dresmnkaos
100
  • May 26, 2008
yeah i capped the line going from the back of the intake to the tab/ tad solenoids ands the line from the front/bottom of the intake to the charcoal canister.
1. what about the line from the egr to the tab/tad solenoids?
2. does that line have to have a source of vaccum or can it be capped?
i read somewhere on here that you can use a resister to keep the CEL light from coming on til you get get a chip to delete that code from the computer.
all this is in effort to rid the engine compartment of all the smog equipment.
thanks guy for your help so far. ive always kept this stuff on with my previous mustangs
4G-KDMP
935
CA
May 26, 2008
  • May 26, 2008
You may want to look here to eliminate your egr, tab,tad and other smog related stuff.
http://rjminjectiontech.com/?p=9
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
D
Brakes 88 LX 5.0 - help! no brakes
  • DRGunn427
  • Feb 26, 2025
Fox 5.0 Mustang Tech Feb 27, 2025
nickyb
