Vaccum lines question.
  • Thread starter Thread starter 98BLKGT
  • Start date Start date Jun 2, 2007
98BLKGT
322
Chicago area
Jun 2, 2007
  • Jun 2, 2007
Ok so I might redo all my vaccum lines since I don't know what the previous owner did. I need some of your guys help with this.
I don't have the smog pump hooked up, no egr, no A/C, no cruise control on the car.
Wouldn't this mean that the only vaccum lines I need is the PCV, fuel pressure regulator, and brake booster? Anything else I NEED vaccum lines running to?
(BTW I have the vac diagram but I just don't think I need all those lines if I don't have the things listed above)
98BLKGT
322
Chicago area
Jun 3, 2007
  • Jun 3, 2007
Anyone?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 3, 2007
  • Jun 3, 2007
Miss connecting the A/C vacuum line and the heater, vent and defroster don't work correctly.
98BLKGT
322
Chicago area
Jun 3, 2007
  • Jun 3, 2007
Even if I don't have A/C on the car anymore?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 3, 2007
  • Jun 3, 2007
The vacuum controls the flapper valves that divert and control airflow.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
98BLKGT
322
Chicago area
Jun 3, 2007
  • Jun 3, 2007
Interesting. Thank you. So I guess I will leave the a/c vac lines in.
So this should be my diagram?
98BLKGT
322
Chicago area
Jun 3, 2007
  • Jun 3, 2007
One other question. On the diagram you see the canister purge valve. It says to hook it up to the vaccum at the throttle body??? The only place I can think of is the little tube that runs to the oil filler neck.
93 LX
3,081
Norwalk, CA.
Jun 3, 2007
  • Jun 3, 2007
on the stock intake it goes to the vacuum tree under the upper intake.
P
Engine Vac line help on a 1985 5.0 carbed stock engine - smog lines removed
  • philcore3
  • Nov 26, 2024
Fox 5.0 Mustang Tech May 18, 2025
General karthief
Smog delete /vacuum lines
  • Serg.Xof
  • Feb 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 18, 2026
RileyDymond
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
