Vacuum in 5.0 at idle?
  • Thread starter Thread starter Piston
  • Start date Start date Sep 25, 2006
Piston
215
Chicago Suburbs
Sep 25, 2006
  • Sep 25, 2006
What kinda vacuum pressure should I expect at idle? At what point does low vacuum affect the brakes in a neagtive way? At 1200RPM's i was seeing 9lbs.
A
Acid7711
41
TN
Sep 25, 2006
  • Sep 25, 2006
The engine load and throttle position play a big part in engine vacuum. I see about 18 inches (if not inches then whatever it is) at cruise in 5th, and about 20 at idle.
I could see that low number causing a problem, but I'm unsure how much vacuum the brake booster requires to fully opperate?
HISSIN50
34
129
Sep 25, 2006
  • Sep 25, 2006
Single digit vac can create issues with the power brake assist. There are some work-arounds for it, but it can be kind of a pain.
I see 19.5" hg at idle (670 RPM).
Good luck.
Piston
215
Chicago Suburbs
Oct 2, 2006
  • Oct 2, 2006
Good luck.
What are the workarounds? The strange thing was my brakes used to work fine with this cam but then all the suddenly they don't. I didn't have a guage to see how much vac I had but I see about 10. I tried revving the car up and got like 15+ and the brakes didn't seem to change.
HISSIN50
34
129
Oct 2, 2006
  • Oct 2, 2006
If things used to work alright before, I'd look for an malfunctioning component (like a bad vacuum hose, etc).
Amongst the easier work arounds for the typical 'big cam' are a simple vacuum cannister/reservoir, or even a pump. The former can be pieced together for very cheap using J/Y stuff.
I'd still give things another once over since this is a new issue.
Good luck.
Piston
215
Chicago Suburbs
Oct 10, 2006
  • Oct 10, 2006
well i ordered a new brake booster hope that helps.
VG30DE
364
Dudley, MA
Oct 10, 2006
  • Oct 10, 2006
I see about 8-9 at idle, the brakes are just starting to get hard... I have just learned to downshift to get the vacuum up and I dont even notice...
Piston
215
Chicago Suburbs
Oct 10, 2006
  • Oct 10, 2006
Yah that's not the problem for sure. But I know what you mean.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Engine Edelbrock 1406 install help
  • scottcarp10
  • Dec 11, 2025
Fox 5.0 Mustang Tech Dec 15, 2025
scottcarp10
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
