Vacuum Leak?
  • Thread starter Thread starter 885.0conv
  • Start date Start date Dec 11, 2010
885.0conv
238
Phoenix, Az
Dec 11, 2010
  • Dec 11, 2010
I am thinking this is a vacuum leak somewhere. I have good power under normal driving conditions but at a light at WOT the car bogs down (I would think that I could do a burnout with the mods on my car). When the car hits about 3K the car wakes up and takes off but driving on the highway at cruising speeds it is fine. The other issue, could be related, when the engine is hot the car cranks but wont start unless the throttle is down. ECT was replaced about 6 months ago. Also fuel is about 40 psi at idle with the vac line on and off which makes me ask another question, should that be different with the line on. I can't see the gauge when driving though. Thanks for any help.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 11, 2010
  • Dec 11, 2010
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
885.0conv
238
Phoenix, Az
Dec 16, 2010
  • Dec 16, 2010
Ran the codes and just got the 11 code. Did notice better response when I bumped the base timing from 14 to 18.
Cobra1741
152
  • Dec 16, 2010
i figured it was supposed to be 38-40 psi with line off. might be wrong on that one. check your plugs, they can tell you sometimes if your running lean on both banks of the motor. initial timing at 18 is a lot.
885.0conv
238
Phoenix, Az
Dec 21, 2010
  • Dec 21, 2010
Could it be the cam?
Just wondering if this problem is due to the cam/head setup. After thinking about it, the problem showed up after I put the heads on. I still have the stock cam in. The person I got the heads off of had a custom cam and he would not sell it to me.
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,056
224
Massachusetts
Dec 21, 2010
  • Dec 21, 2010
Should get three 11's
One for KOEO
One for CM
and one with engine running for KOER codes
After the three 11's, run the cylinder balance test and confirm all 8 cylinders are contributing equally. WIll rule out a weak injectors
F
FobraR
120
Southern California
Dec 21, 2010
  • Dec 21, 2010
I'm sure that Hissin or Joe will chime in again with more test info for you. You said the fuel psi is the same with or without vacuum. With vacuum at idle, the psi should drop. Without vacuum is your max psi setting for WOT. If you have no change in the fuel psi, you may have a bad regulator, gauge, or a vacuum problem. You're going to have to hookup a vac gauge to the manifold and test from there.
Do you have a repair manual? It's a great $20 investment for reference.
885.0conv
238
Phoenix, Az
Dec 22, 2010
  • Dec 22, 2010
Did all three test, I got 11 on the three and on cylinder balance test the code kept giving different numbers. 8,6 the first run and the 2,1 the second run, and 5,3 the third one. Going to buy a manual had one but its falling apart from being used a lot. Also noticed fuel pressure was at 35 psi (down from 40 psi) and rpms at 1500 during the balance test.
885.0conv
238
Phoenix, Az
Jan 4, 2011
  • Jan 4, 2011
Went and checked the lower intake after looking up some posts. The lower was a little loose so torqued them to 18 ft/lbs. Also replaced the upper intake gaskets with thicker ones. Noticed that there was a fair amount of oil in the upper intake. Only give me the 11 codes and cylinder balance test is good. Still feels like it should be more power also after I let off the throttle after WOT there is some afterfire through the tailpipes.
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sep 26, 2026
AlexM556
A
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
