vacuum lines
  • Thread starter Thread starter DemonMustang
  • Start date Start date Apr 2, 2005
DemonMustang
298
Saskatoon, Sk
Apr 2, 2005
  • Apr 2, 2005
anybody a link to a good diagram for where all the vacuum lines for 1988 5.0
HISSIN50
34
129
Apr 2, 2005
  • Apr 2, 2005
courtesy of S&2B's (site host) and Tom (drawing author):
http://www.veryuseful.com/mustang/tech/engine/images/88Stang5.0Vacuum.gif
DemonMustang
298
Saskatoon, Sk
Apr 2, 2005
  • Apr 2, 2005
thanks very much dude
HISSIN50
34
129
Apr 2, 2005
  • Apr 2, 2005
welcome Duuuuuuuuuude.
FreeGT
81
St. Louis
Apr 3, 2005
  • Apr 3, 2005
That link rocks, I used it when I installed my KB blower. Can I ask what your doing w/ the vacuums lines, poweradder or something? I'm just in the same boat, and if you are to, I'd be interested in hearing about it.
DemonMustang
298
Saskatoon, Sk
Apr 4, 2005
  • Apr 4, 2005
actually i just finished rebuilding the short block. when we tore the motor out my buddy was in a hurry and just pulled all the lines, i didn't get a chance to see where they all went, and he forgot. So i was kinda in a pickle. But everything is good now, except one line that comes out the front of stock intake. I know it was somewhere before and its really short.
So i just plugged it for now, and everything runs great.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 4, 2005
  • Apr 4, 2005
That's the line for the charcoal canister purge valve that vents the gas tank.
Charcoal canister plumbing - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel.
It does not weigh but a pound or so and helps richen up the cruse mixture. It draws no HP & keeps the car from smelling like gasoline in a closed garage. So with all these good things and no bad ones, why not hook it up & use it?
DemonMustang
298
Saskatoon, Sk
Apr 4, 2005
  • Apr 4, 2005
didn't know that thanks
J
JJPA
59
Lancaster,PA
Jun 5, 2005
  • Jun 5, 2005
im actually redoing all the stuff that this guy i bought my 5.0 off of. Im pretty sure there is no canister purge or charcoal canister on it. There are also 4 nipples on the intake that are capped. I now know that 1 is for the charcoal canister. What could the other 3 be.
Engine vacuum
  • KAWMAN2
  • Aug 1, 2026
Fox 5.0 Mustang Tech Aug 7, 2026
Mustang5L5
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Engine Edelbrock 1406 install help
  • scottcarp10
  • Dec 11, 2025
Fox 5.0 Mustang Tech Dec 15, 2025
scottcarp10
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
