Electrical Vacuum tree-ac line
I noticed the line coming out of my vacuum tree for ac is not hooked up. Where does this plug into?
There's supposed to be a black little plastic hose sticking out by where the heater hoses go through the firewall. That line runs to a 3 port check valve. The side on the same side as that little black line goes to a vacuum reserve ball behind the passenger fender. The other side of that check valve runs to that AC spot on the vacuum tree.
Reactions: 859foxbody
See pictures below....
The AC line from the tree traces along the firewall behind the upper intake and connects to a plastic check valve as Described in the above post. I hope these pictures help.
Good stuff Matty...
91 here also so if any pics are needed that can help you just ask.
im trying to delete smog first I ran shorter belt but now it's squeaking from the idle pulley from time to time and it's brand new I'm looking for the idle pulley so I can run the stock belt and I put a cap on the smog tube but how do I cap the hole in the h pipe someone said make it flat and JB weld it but it's on the car still thank you again here's my 91 gt and it took me forever with a new distributor to set it
