  • SN95 4.6L Mustang Tech
valve adjustments
  • Thread starter Thread starter Team Ford
  • Start date Start date Oct 30, 2006
Team Ford
109
  • Oct 30, 2006
Do the valves on a 02 4.6 2v need to be adjusted at 55K? I hear lots of noise coming from the top of the motor when its cold, allot of chattering
RandyStinchcomb
1,159
Randallstown, Md
Oct 30, 2006
  • Oct 30, 2006
nothing you can adjust, what weight oil are you using?
Team Ford
109
  • Oct 30, 2006
Mobil1 synth 0-30 or 5-30. I change it every 3-5k miles with filter. I did just run half a can of seafoam in the oil for 500 miles or so. Man wasnt the oil black black black when I changed it.
stangGT97
1,299
Boston area, MA
Oct 30, 2006
  • Oct 30, 2006
Are you sure your factory chain tensioners arent taking a dump? I think they get kinda lazy with age, might be wrong though
Team Ford
109
  • Oct 30, 2006
Good question. How can I check?
RandyStinchcomb
1,159
Randallstown, Md
Oct 30, 2006
  • Oct 30, 2006
not an easy thing, you'll have to remove the frt chian cvr Ford did put a cheaper plastic/nylon tensioners on the 4.6 in @2001 and there have been some issues, alot of people when they do a rebuild will get the older steel tensioners. did it make the noise before seafoaming?
Team Ford
109
  • Oct 30, 2006
Thanks Randy.
I could hear it before...it started getting noisy in the past 10k miles or so. I will have to make a quick video of it.
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
