  • 1994 - 1995 Specific Tech
Valve damage indeed!!!!!
  • Thread starter Thread starter Guero
  • Start date Start date May 22, 2006
Guero
2,148
May 22, 2006
  • May 22, 2006
well i took the heads of, and on the passenger side there was one intake and one exhaust, and on the driver one, it was only 1 intake. i ordered them of summit already ill get them ready asap, i wanna make it to the track this friday!!!!!!!!!!!!!!!! what you think ill get charged for that?
BlackVert
5,589
9
98
Bethesda, MD
May 22, 2006
  • May 22, 2006
please don't rush through the job or you will break something else!
Guero
2,148
May 22, 2006
  • May 22, 2006
if i can get the heads done by thursday, that leaves me more than enough time to put everything back on. with out rushing, thats the last thing i want to do. right now
Guero
2,148
May 22, 2006
  • May 22, 2006
by the way the ones that dont go in all the way, those are bent duh, those are the only ones right?
Dan95-5.0
1,110
Manitoba, Canada
May 23, 2006
  • May 23, 2006
an easy way to check is put it in a drill press and you'll see it wobble.
O
oosmytoo
530
Portland - Oregon
May 23, 2006
  • May 23, 2006
ahh no good! we just finished up a Trick flow kit on my friends car, and we didnt tighten down the timing chain bolt, so it backed out. broke the timing chain, and bent two intake valves!
although we got lucky, it did not scar up the valve seats at all. ordered the new valves from summit, bought some valve grinding compund, popped the new valves in, spun them to make sure it looked like they would seat ok, and they were fine. reassembled the motor, and for 500+ miles now nothing has gone wrong, sounds excellent!
just take the extra time to check out the other head, if you havent already? make sure you dont have a compressed lifter, or bent pushrod?
Guero
2,148
May 23, 2006
  • May 23, 2006
i got the other head out. we messed up on the lifters. i had to replace every single one!!!!! but it finally looks like its going my way
Zero Signal
2,633
Tucson, AZ
May 23, 2006
  • May 23, 2006
Ouch, what did you do to the lifters to mess them up, max out the adjustment or something?
You should post some pics of all this stuff.
Guero
2,148
May 23, 2006
  • May 23, 2006
i put the x that hold the lifters in place wrong. so all moved freely to the sides. the wheel on each had marks at the ends. they when it broke one of them busted a 180 and stoped the cam. and caused all this unnessecary stuff
Zero Signal
2,633
Tucson, AZ
May 23, 2006
#10
  • May 23, 2006
  • #10
Ohhhh yeah that's right, I was thinking rockers when you said lifters for some reason. Duhh
1TallMF
955
Montreal
May 23, 2006
#11
  • May 23, 2006
  • #11
So, with that one lifter that did the 180, was there any scratches on the cam lobe?
Guero
2,148
May 23, 2006
#12
  • May 23, 2006
  • #12
yeah i bought a new one. the whole cam had marks
I
IEatRiceGT
150
MD
May 23, 2006
#13
  • May 23, 2006
  • #13
ouch...
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
