  • 1994 - 1995 Specific Tech
valve job questions
  • Thread starter Thread starter BlackVert
  • Start date Start date Aug 30, 2006
BlackVert
5,589
9
98
Bethesda, MD
Aug 30, 2006
  • Aug 30, 2006
if you have been following my threads, you know i am having oil loss problems.
i am burning about a quart of oil per tankful, or about every 200 miles
the compression test indicates that my rings are most likely not the problem. phew!
people say that the next most likely culprit is the valves.
i want to talk to some local shops about what would need to be done if the oil is coming through the valves somewhere, but this is one of the many areas in which i am ignorant, so i don't know what questions to ask, and i don't want to come across sounding like a total idiot when i talk to them. sooooo ....
what should i be asking them to quote me a price for?
exactly what is a valve job?
what is a 3-angle valve job?
what are valve seals and should they be checked/replaced?
what are valve guides and should they be checked/replaced too?
BlackVert
5,589
9
98
Bethesda, MD
Aug 30, 2006
  • Aug 30, 2006
ttt
WhiteDevil
2,717
San Diego
Aug 30, 2006
  • Aug 30, 2006
If oil is coming into your clylinders from the heads it is going to be through the valve seals. They are little rubber caps that sit on the valves to prevent this. But after time and lots of heat get to them get get hard as rocks. Mine were like hard plastic. Then they start to leak. How many miles are on the car? Most likely a lot of things need to be serviced but its hard to say what you budget for this is.
BlackVert
5,589
9
98
Bethesda, MD
Aug 30, 2006
  • Aug 30, 2006
the car has about 110K miles on it.
the heads have about 20K miles on them, i got them from thumper.
could having the blower on there have had something to do with a valve seal failing? i didn't have a problem before the KB was on there. maybe too much crancake pressure or something?
maybe i can do the valve seals myself? i've been reading up on it and it looks sort of doable
are they like this in our engines?
http://www.totalrpm.com/article/449
AznStanger3v
2,026
Northern VA
Aug 30, 2006
  • Aug 30, 2006
this is strictly my opinion, so take it like a grain of salt.
I disagree with everyone when they say its the valve seals. That is A LOT of oil loss for the seals. there really isnt that much oil in the rocker area. I still think its your rings. I havent been following your threads so i dont know your compression results. but here is my take on it. I sure you got decent readings because you were doing a "wet" compression test without knowing it. the difference between a wet and dry compression test is the use of oil during the compression test itself. the oil might be sealing the rings during your compression test and not burning due to no spark.
so, im still saying its your rings. a leak down test would prove more useful in my opinion.
SorsCode
20+ Year Stangneter
Jun 10, 2003
1,024
434
113
St. Louis, MO
Aug 31, 2006
  • Aug 31, 2006
I was having the same problem you describe. But I was burning oil a little quicker. Mine was so bad I could let it idle for 10 minutes pull the lower intake and look into the intake port of the cylinder giving me problems and oil would just puddle on top of the valve. Mine was an AFR. here to find out the valve guide was not installed to tolerance. Wish we would of found this out the 3 times I sent them the head. Rings are still a possiblity in your case compression test won't always show that. leak Down test does though. But I figured I would tell you my case. Might help might not.
PS lets just say the outcome of mine wasn't good. Ended up breakin the valve. Thats when AFR came back the 3rd time and told me my problem.
BlackVert
5,589
9
98
Bethesda, MD
Aug 31, 2006
  • Aug 31, 2006
so are you saying that the oil is creeping up the cylinder walls past the rings and getting into the cylinders that way, or is air making it past the rings during the compression stroke and pressurizing the crankcase, causing oil to be forced through the PCV valve into the intake?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 31, 2006
  • Aug 31, 2006
When rings get tired .................
They can't seal the wall as tightly as thay once did.
You have more oil left on the wall and it gets pushed up to the top and then gets burned with the rest of the charge.
The whole process is called ... high milage oil consumption
Some times you have oil that gets past loose guides and then it is only a matter of time before the seals can't do their job as John talked about.
Since your heads were redone not too long ago ... Like has been said ...
Most likely ... that ain't your prob
Grady
BlackVert
5,589
9
98
Bethesda, MD
Aug 31, 2006
  • Aug 31, 2006
Grady
but i also have the big cloud at startup?
is oil in the upper intake also an indication of old rings (excess pressure getting thru and overwhelming the pcv system)? i wouldn't think a valve seal problem would result in oil in the upper intake
oil in the upper could also explain the big cloud on startup as it would settle at the valves while it sits and then get burned upon startup
should i stop in on my mechanic and schedule time for a leakdown test, or is that unnecessary if we really doubt that it is a valve seal issue?
AznStanger3v
2,026
Northern VA
Aug 31, 2006
#10
  • Aug 31, 2006
  • #10
i highly doubt the seals, but i would still have a leak down done on it. your PCV must be overwhelmed by the blowby that it is putting oil in the intake. that is my theory.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 31, 2006
#11
  • Aug 31, 2006
  • #11
When you see that ...... some of the time ..............
That is an indication of bad seals.
You kill the motor and over night, oil runs down the valve stem past the seals and into the chamber.
Cloud city on the first fire up in the morning.
btw ... I got a bit of oil in my upper intake as well due to me being too lazy to rig up a splash guard in the fill tube of my modded fox vc's to replace the original one that met a violent death from my die grinder and porting burr.
I don't get a cloud startup thing from that little bit of oil in the upper.
Grady
WhiteDevil
2,717
San Diego
Aug 31, 2006
#12
  • Aug 31, 2006
  • #12
Yeah with valve seals that new i would start to look elsewhere for your problem. Mine were 100k old and lost about 1qt every 3k miles.
reddy351
560
12
38
Columbus, Ohio
Aug 31, 2006
#13
  • Aug 31, 2006
  • #13
I'd say that your next stop should be a leakdown test. I wouldn't recommend just throwing parts at it, to try to fix it.
If/when you call a machine shop (20k mile heads shouldn't need rebuilt.) you'll ask them what they charge for a valve job. What type? A valve job is matching the angle of the edge of the valve to the valve seat. Most shops do a 3-angle valve job. This means that in addition to matching the seat and the valve to each other, they also use an additional cut to "round off" the seat area. This reduces the amount of turbulence created by the valve seat. A 5-angle uses 4 additional cuts, almost like porting the seats.
Guides can be "knurled" or replaced. Knurling is really a band-aid repair. It's used to bring slightly worn guides back to service. They can be cut out and replaced with bronze "bushing" type guides at much more expense, but also more longevity.
Seals are just popped off and new ones popped back on when disassembling the heads for service.
I hope this helps.>>>>>>>>LEAKDOWN test, FIRST!
94-302-vert
1,947
NE CT
Aug 31, 2006
#14
  • Aug 31, 2006
  • #14
Take that PCV line, run it into a 2 liter bottle of soda, plug it off at the itake and drive it around the block.
If oil is getting into the upper at 1qt every 200 miles then you will have plenty of oil in the bottle after a 5 or 10 mile run...
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 31, 2006
#15
  • Aug 31, 2006
  • #15
One more possible thing to think about Chris
Was it you that had some vt geom issues not too long ago
If so ... you may have put more wear & tear on the guides/seals.
Several years ago ... when there were not as many options with head choices ... you would see peeps convert oem iron heads over to stud mount
Some of the time, when they did that and did not ensure the vt geom was up to snuff ... You'd see them crying about trashed vg's not too long after the conversion. If the angle is too radical ... you very well can get some binding going on in that area.
Again ... Just a thought
Grady
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
