  • 1994 - 1995 Specific Tech
Valve spring help
  • Thread starter Thread starter pirotec354
  • Start date Start date Sep 13, 2008
pirotec354
127
Grand Rapids, Michigan
Sep 13, 2008
  • Sep 13, 2008
Hey guys Quick question. I just bought a new cam from comp cams. What type of valve springs would work well with this cam.Im not sure how strong of springs to use. Any suggestions would help. Thankyou. Heres the specs:
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,800-6,000
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 236
Duration at 050 inch Lift: 230 int./236 exh.
Intake Duration: 274
Exhaust Duration: 286
Duration: 274 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.520 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.523 in.
Valve Lift with Factory Rocker Arm Ratio: 0.520 int./0.523 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
earleys94gt
1,223
Ashley, Ohio
Sep 13, 2008
  • Sep 13, 2008
Contact Comp Cams, they prob. have the ones you need.
If they do not have the springs you need, they can give you the specs. on them.
thesargster4
23
  • Sep 14, 2008
Hmph, i thought sbfs from the late 90's were roller? or am i wrong..?
TomCat
412
Utah
Sep 14, 2008
  • Sep 14, 2008
I think you're right there.
BREWTUS428CJ
66
Lake Elsinore, CA
Sep 15, 2008
  • Sep 15, 2008
The part number on your cam is: 31-246-3, that cam is a horrible choice for a 5.0, unless youre working on something much older its a bad choice. If youre gonna run that you need to change the pushrods and lifters too. If you're really planning on installing that into an SN, send that thing back and get the right roller cam. I dont know what else your running, but the 35-312-8 is pretty close.........
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
G
4.6L rods and piston into a 5.4L
  • Green mustang
  • Jun 11, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 11, 2025
Green mustang
G
