valve spring shim help........
  • Thread starter Thread starter LX2NV
  • Start date Start date Apr 30, 2007
L
LX2NV
10
  • Apr 30, 2007
hey all, i was changing the seals on my gt40p's and noticed my spring shims were kind of sharp and worn. i used the trick flow valve spring upgrade kit from summit. i figure i better change these out real soon before bad stuff goes down. can anyone reccomend a tough shim, and also what size i.d. and o.d. shim will i need ? thanks fellas............
Mustang78
486
Aberdeen, WA
Apr 30, 2007
  • Apr 30, 2007
are you talking about the thick spacer lookin thing on top of my exhaust valve springs?? i have GT40 heads and wonder the same thing..sorry i dont have anything helpful to add, but how much were the springs? i need to buy a set
~Mark~
TomCat
412
Utah
Apr 30, 2007
  • Apr 30, 2007
AFIK stock heads didn't come with spring shims... Mustang78, what you are describing are the exhaust valve rotators. Pretty simple to replace... you can pull them off and check how well they rotate and any parts store would be able to get them for you. Shims sit below the valve spring against the head to help you get the correct installed height so your spring tension is correct.
Anyway, I believe the correct sizing is 1.031" ID and 1.500" OD... that's what I used.
Fox Valve Spring Kit PAC-1219X. Help finding needed additional parts.
  • 93gtmustang
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2026
93gtmustang
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Engine TFS Valve spring kit shims
  • sav22rem22
  • Apr 7, 2023
2K
Fox 5.0 Mustang Tech Apr 8, 2023
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
