  • SN95 4.6L Mustang Tech
valve tap?
  • Thread starter Thread starter pumm3l
  • Start date Start date Aug 16, 2006
First Prev 2 of 2
slow3gt
117
nashville tn
Aug 20, 2006
#21
  • Aug 20, 2006
  • #21
my car does that too but you can hardly hear it unless you are between two buildings but i dont know what it is prolly just a noisy motor or the cams in it
Blue2kMustangGT
30
Cedar Brook, NJ
Aug 22, 2006
#22
  • Aug 22, 2006
  • #22
pumm3l said:
just got in from changing the oil.....no metal fragments or silverish looking oil thank god, tomorrow I'm gonna try to pull the valve covers and then go from there.
Any luck?
H
huudoo
18
Knoxville TN
Aug 22, 2006
#23
  • Aug 22, 2006
  • #23
their is a service bulleetins from Ford - article no. 03-25-6
ENGINE - ROMEO BUILT 4.6L 2V - TICK NOISE FROM ENGINE - ENGINES BUILT BEFORE 9/17/2003
also look here
http://forums.mightymustangs.net/index.php?showtopic=2165&st=15&
pumm3l
20+ Year Stangneter
Feb 4, 2003
105
Somewhere out there
Aug 25, 2006
#24
  • Aug 25, 2006
  • #24
okay so I took the car to a mechanic to check it out, he says he's 95% sure it's a sticky lifter or maybe the timing chain (probably unlikely).
sooooo after blowing up an engine once, and hurting this one I plan on doing a rebuild so I don't have to worry about wether I have a car this week when when i'm spraying.
I've been doing a lot of research on the internals of an engine and I'm still doing it....I found a site for a set of Diamond forged rings, pistons, rods and bearings for $1300 they claim it's good up to 700 hp and maybe find a cobra crank. now my goals are simple, I want a car that I can drive everyday to work without sacraficing more gas milage then I already am with the occasional 150 shot now and again when I hit the track. That should put me around 400 on the juice. I see a lot of info in the boards about building up the block but I don't really see much on the heads....I'm not looking for added performance with the heads in my current plans so I'm staying with the stock cams, etc but what can I do to add some durability to my heads to withstand the 150 shot?
pumm3l
20+ Year Stangneter
Feb 4, 2003
105
Somewhere out there
Aug 25, 2006
#25
  • Aug 25, 2006
  • #25
also look here
any idea if I'd have a problem with them checking my engine out since it's not the original motor?
First Prev 2 of 2
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
C
Valve stem tip tap?
  • Coolen
  • Apr 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 14, 2025
