  • 2.3L (N/A & Turbo) Tech
VAM problem
  • Thread starter Thread starter Rayzr
  • Start date Start date Jul 8, 2011
R
Rayzr
17
  • Jul 8, 2011
Hello fellow stangnet members, i've had my 89 2.3 turbo hatch for a year and a half. I have done some mods to it. Ported head and manifolds, I then decided to do the blow through vam mod 2 days ago. I took the cover off the vam, and my first mistake was not to mark the vam spring where its at stock. I then unscrewed the tiny screw too much and the whole spring unwound. My Question is.. Is there a picture or some kind of reference of some kind where I can place the spring back to its stock location? Your replies are much appreciated
K
KhanTyranitar
93
Jul 10, 2011
  • Jul 10, 2011
Unfortunately I cannot be of much help there, but I would recommend either doing a MAF conversion or switching to speed density. The VAM is a restriction on the intake, it makes your turbo work harder to get air. Even doing the blow through, it is restrictive, and moving away from it is a better option in the long run if you are trying to get more power. The MAF conversion requires over riding the stock programming, which you have to do for a blow through VAM if you want reliable results anyway. A MAF produces far less resistance to flow than a VAM. the 90mm lighting MAF is a good choice, then you need the connector to plug in. You should be able to find instructions on the conversion. Then you can run a Jaybird or Quarterhorse on your stock ECU to allow it to interpret the new signal correctly.
The speed density doesn't use the VAM or a MAF, but rather uses a MAP sensor to measure vacuum or boost, and combined with RPM, intake temperature, throttle position, and known constants (injectors size, displacement, and a custom made fuel and timing map), allows the computer to calculate how much air the engine is flowing, and therefore how much fuel the engine needs. No restrictions, and overall, for performance purposes, is better than a VAM or MAF.
Unfortunately, I don't know about the spring position.
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
Q
Ignition Coil SPRING COMPRESS TO TOP OF PLUG???
  • Scwhitten
  • Mar 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2025
Scwhitten
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
