vehicle not responding
  • Thread starter Thread starter Raginstang
  • Start date Start date Apr 2, 2005
R
Raginstang
166
SANTA CRUZ CA
Apr 2, 2005
  • Apr 2, 2005
so after moving all my wires to the fender, I have a check engine light., I tried to scan it and it says vehicle not responding? what could I have not hooked up for the data link not to send a signal to the cpu, and if I try to manually prime the fuel pump, it wont work "through the data link". but the car runs, but really crappy, anyone else have this problem ever?
whtpny
338
Spokane WA.
Apr 2, 2005
  • Apr 2, 2005
I had that once but the battery was too low to scan. I would double check that both of the pugs are fully in the scanner then trace them to make sure they are not cut or shorted somehow.
Good luck keep us updated.
R
Raginstang
166
SANTA CRUZ CA
Apr 2, 2005
  • Apr 2, 2005
they are all the way in the scanner, and if I try to jump the data link to read the codes off the dash,"check eng light blinks," it does nothing, like the cpu doesn't even see the data link.
vikingpower
656
CWU Ellensburg, WA
Apr 2, 2005
  • Apr 2, 2005
Undo what you did with all the wires and you'll find the problem, I bet its just a shorted connection.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • brandyn200
  • Jun 20, 2026
AeroCoupe
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
1990 foxbody 5.0 fuel system.
  • staceyj
  • Nov 28, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Mustang5L5
