Vert questions?
  • Thread starter Thread starter MUSTANGJOE
  • Start date Start date Mar 31, 2006
MUSTANGJOE
Silver Stanger
1,644
17
59
Mar 31, 2006
  • Mar 31, 2006
Hey guys...
Looking at a vert...owner says the top is new but needs top seal were the top meets the windshield...what exactly is this and where can I buy one?
Tried 50resto but cant find it ,,,unless theres another name to it,,thxs
TheBocSez
652
Converse, TX
Apr 1, 2006
  • Apr 1, 2006
It is exactly what he described, a piece of weatherstrip that extends from the 1/4 window all the way around the front to the other 1/4 window. It sits in a channel around the top frame and seals it to the windshield and door glass. I got mine from 50resto under part number LRS-53986D. They can also be bought on ebay http://cgi.ebay.com/ebaymotors/1985...33685QQitemZ8052738574QQrdZ1QQsspagenameZWDVW The run about 80.00.
MUSTANGJOE
Silver Stanger
1,644
17
59
Apr 1, 2006
  • Apr 1, 2006
Thanks...is this an easy install?
TheBocSez
652
Converse, TX
Apr 1, 2006
  • Apr 1, 2006
That I dont know. I am having mine installed with my new top.
xpeteyjtx
108
Taunton, MA
Apr 1, 2006
  • Apr 1, 2006
I recently installing the 50resto header on my vert... It is very easy to install. Just rip the old stuff out, clean out any left over glue/residue, install new header, make sure it fits nice, then use some weatherstripping adhesive to keep it in place. The Ford part is slightly superior because it is thicker (where the frame meets the windshield). So when you install the new piece, you may have to adjusts the latch j-hooks by 1 or 2 turns to get a better seal.
xherdlr
159
Hendersonville,Nc
Apr 2, 2006
  • Apr 2, 2006
You can get them from your local Ford dealer...When you install,dont glue it down. Then if you have to replace the top,the new weatherstriping wont get damaged...Im glad I didnt,because I have replaced 3 tops since I bought the weatherstripping...Car was broken into 3 times in 2 years...
Kelly
MUSTANGJOE
Silver Stanger
1,644
17
59
Apr 2, 2006
  • Apr 2, 2006
Thanks guys..
Thats what Im scared of by getting a vert,,people cutting the top and stealing stuff. Do they have any special alarms to prevent this..also do the insurance company pay you a new top if you have full coverage? Thanks
Lemonade
827
San Ramon,CA
Apr 2, 2006
  • Apr 2, 2006
MUSTANGJOE said:
Thanks guys..
I have a Clifford alarm with proximity sensor. If you get near my car it chirps to warn you. The sensitivity is adjustable. It's nice to be able to arm the alarm & leave the top down & not worry about the top or interior.
Lems
MUSTANGJOE
Silver Stanger
1,644
17
59
Apr 3, 2006
  • Apr 3, 2006
Lems
Thanks I'll look into that..
bsedwebt70-5.0
320
Charlottesville, VA
Apr 3, 2006
#10
  • Apr 3, 2006
  • #10
insurance will pay for new top and install if it is cut getting broken in to - they will depreciate it based on age/wear etc... if necessary as they owe for what was there - I am an insurance adjuster in VA who has had to do this several times over the years - not too often as you would think - unless you have enemies you will probably be ok - it is lots easier to bust the glass from what I have seen - we pay for the glass if busted too - always bolt down your stuff - insurance does not cover items that are not permanantly attached to the car - velcro and double sided tape does not count
MUSTANGJOE
Silver Stanger
1,644
17
59
Apr 5, 2006
#11
  • Apr 5, 2006
  • #11
Thanks..
I always see verts near my area with a taped up rear window..I figure someone cut it to get something
spyne
78
Fairfax, VA
Apr 6, 2006
#12
  • Apr 6, 2006
  • #12
MUSTANGJOE said:
Thanks..
If it's a plastic rear window it probably just cracked due to age.
RYC CUKR
1,437
Orlando
Apr 6, 2006
#13
  • Apr 6, 2006
  • #13
If it is the glass rear window more than likely the glass and top material have seperated at the bottom of the glass. Had that problem on my 93 when I bought it. Needed a new top anyway though so I had it all done at once.
Need help 94 GT convertible top leaking
  • Scott94gtvert
  • Aug 9, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Aug 9, 2025
General karthief
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
