very wierd problem
  • Thread starter Thread starter 87foxstang
  • Start date Start date Jul 13, 2007
87foxstang
Cromwell, CT
Jul 13, 2007
  • Jul 13, 2007
The mods done to my car are in my sig....but the car is running rich
The plugs are fouled, the gas is diluting the oil in the oil pan...I put the cobra intake on and i did it right, checked for vaccum leaks and there are no signs of any. BUt heres the thing, its running rich yet my fuel pressure guage on the schrader valve says 36psi, which is lower than what it should be, should be 39 if i remember right.
Well i put the BBK adjustable fuel pressure regulator on because the stock one was shot, and when i adjust it leaner or richer it doesnt change on the gauge
I am at a serious loss, can anyone please help me out here.....thanks in advance
I
izzleon
22
  • Jul 13, 2007
gauge
try a different gauge oh and make shure ur checking the psi with the engine on
vristang
4,933
101
124
Seattle
Jul 13, 2007
  • Jul 13, 2007
What gauge????
Wideband O2 sensor or the stock O2 sensor???
Are you checking fuel pressure with the vac line disconnected from the regulator????
jason
87foxstang
Cromwell, CT
Jul 13, 2007
  • Jul 13, 2007
yes the engine is on, in not that bad hahaha.
The O2 sensors are bosch, and yes the vaccum line is dissconnected
the gauge is from NAPA
bill302
2,131
alabama,gadsden
Jul 13, 2007
  • Jul 13, 2007
i dont know much about speed density but if you are sure you have no vacuum leaks do you have the bap sensor hooked up properly with the vacuum hose and where are you pulling the vacuum from...intake right. also you might want to check the line for leaks to ensure its not stopped up.
87foxstang
Cromwell, CT
Jul 13, 2007
  • Jul 13, 2007
What is the BAP sensor?
And yes the vaccum is being taken from the intake, and the hoses are all new and i checked for leaks, so thats ruled out
Hizzle
51
Fort Carson, CO
Jul 13, 2007
  • Jul 13, 2007
One thing I have found from experience and talking to others is the BBK regulators are junk. Also, I had a ton of problems with speed density with just a couple of mods and then I did the MAf conversion and all was well
bill302
2,131
alabama,gadsden
Jul 13, 2007
  • Jul 13, 2007
i may have made a mistake bp sensor...i know enough about speed density to get me in trouble...lol
Here is a quote from the Ford Fuel Injection page.
"The Barometric Pressure (BP) sensor operates as a piezoelectric (pressure-sensing) disc. However, rather than generating a voltage, its output is a frequency change. The sensor changes frequency relative to intake manifold vacuum. The sensor frequency increases as vacuum increases. The BP sensor is used to sense the changes in barometric pressure, allowing the PCM to sense the altitude at which the vehicle is operating. Its signal affects air/fuel ratio, spark and EGR for altitude compensation."
bill302
2,131
alabama,gadsden
Jul 14, 2007
  • Jul 14, 2007
http://kemparts.com/TechTalk/tt11.asp
HISSIN50
34
129
Jul 14, 2007
#10
  • Jul 14, 2007
  • #10
Any codes?
Bill was leaning towards what I was pondering - the MAP and BAP are the same, but the function of a MAP is about 100 times more important than a BAP. Ensure the MAP is receiving a true vac signal.
FWIW, at idle you should see near 20" of vac.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 14, 2007
#11
  • Jul 14, 2007
  • #11
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
89 through 95 cars have a working Check Engine light. Watch it instead of a test lamp.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
V
v8only
2,378
22
49
Jul 14, 2007
#12
  • Jul 14, 2007
  • #12
the single most important thing to keep a speed density system in check is a good vacuum signal to that map.
btw, I'm guessing the cam you're running is speed density compliant?? If not, there is your problem first.
before checking anything, even codes, you need to start off checking your vacuum signal. 17-20 pounds is fine, don't accept less. I had a vacuum problem to my map, and it didn't pull a single code.
after checking vacuum pressure, then pull off the vacuum line from the map with the car off, and suck on it, if the line is free and clear, you should be able to suck air through it no problem. If you're blocked up, then clear it out.
87foxstang
Cromwell, CT
Jul 14, 2007
#13
  • Jul 14, 2007
  • #13
thanks for the resoponces guys...i do have vacumm, about 17"...i guess ill have to try to pull some codes
  • Mindseye007
  • Aug 16, 2026
Mindseye007
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
  • dan50
  • Jul 18, 2026
dan50
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
