Viberation
  • Thread starter Thread starter Alarus
  • Start date Start date Jan 7, 2006
Alarus
226
Az
Jan 7, 2006
  • Jan 7, 2006
When i get off the gas almost all the way, i get a really bad vibration at about 55+mph, it goes away if i push the gas down a little bit or i get off compleatly, also if i put it in nutral it will vibe. any ideas what it might be?
i was thinking maby a carb issue, but it still dose it in nutral, what about tie rods or wheel bearings? i think my bearings need packed, and i think i need new tie rods...
ashford
485
fargo ND
Jan 8, 2006
  • Jan 8, 2006
sounds like a u-joint going out, or a loose yoke on the rear end
thehueypilot
1,084
Medina,Tennessee
Jan 8, 2006
  • Jan 8, 2006
I agree....u-joint on drive shaft.....more than likely the rear.
Alarus
226
Az
Jan 9, 2006
  • Jan 9, 2006
alright ill look into that, i might be taking it to the shop tomarrow, have them work on it, tierods, tires, alinment, and have them see what else it NEEDs (mechanic is a friend of mine so he wont lie to make money, ive ran into a cupple of those ppl) any other ideas?
Alarus
226
Az
Jan 10, 2006
  • Jan 10, 2006
i was told that it might be a prob in the diff. i got 4 new tires, they guy said that my passenger side inner tie rod is a little loose and i need new strut rod bushings, but he didnt have time to look at the u-joints, any ideas of what else can be wrong, when im going at low speeds i hear a little "thunk" every once in a wile if i tap the gas?
rbohm
6,698
550
204
tucson,az
Jan 10, 2006
  • Jan 10, 2006
get under the car and see if the front u-joint is loose. just grab the driveshaft and twist it back and forth. if the driveshaft moves you have found your problem.
Alarus
226
Az
Jan 11, 2006
  • Jan 11, 2006
anyone know what size mine are?
Alarus
226
Az
Jan 12, 2006
  • Jan 12, 2006
well got it fixed, i think both of them were bad, anyway, i replaced them and took the car out for a spin, no more vibrations, thx alot forwhat imput was given
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
