  • 1994 - 1995 Specific Tech
Vibration before transmission...help!!!
  • Thread starter Thread starter TrueBlue95GT
  • Start date Start date May 3, 2005
TrueBlue95GT
966
Connecticut
May 3, 2005
  • May 3, 2005
I've got a vibration at 3k thats in all gears and neutral that only happen's sometimes. When the car is still cold the vibration isn't as bad and then when it warms up, it's pretty bad and almost unbareable on the highway. I did put in solid motor mounts but I think those just made the problem noticeable. What could this be?
94-302-vert
1,947
NE CT
May 3, 2005
  • May 3, 2005
What condition is the harmonic balancer in?
Chris
davins130
424
  • May 3, 2005
sounds like someone has a bad balancer
TrueBlue95GT
966
Connecticut
May 4, 2005
  • May 4, 2005
I replaced the balancer with a SFI spec one. I'm thinking it might be the flywheel. Does anybody know how its supposed to go up. I changed the flywheel when I changed the clutch and I may not have put it up right.
94-302-vert
1,947
NE CT
May 4, 2005
  • May 4, 2005
This started with a clutch change?
Chris
slytherin
702
northeast ohio
May 4, 2005
  • May 4, 2005
Maybe the wrong flywheel or incorrect install of the dampner. This is a strange one?
TrueBlue95GT
966
Connecticut
May 4, 2005
  • May 4, 2005
I'm not sure when it started happening because I just noticed it when I changed the motor mounts to solid ones. I'm wondering if the weight on the flywheel balances the flywheel or does it help to balance the whole rotating mass of the crankshaft and dampner? If so, how do you know how to clock it.
94-302-vert
1,947
NE CT
May 4, 2005
  • May 4, 2005
From what I understand the bolt holes on the flywheel & crankshaft are keyed so it can only go on one way.
That 50oz imbalance is to balance the whole crank assembly not just the flywheel.
Chris
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
