  • SN95 4.6L Mustang Tech
Vibration problem
  • Thread starter Thread starter 00BlkStangGT
  • Start date Start date Mar 7, 2007
00BlkStangGT
46
Pleasanton, Ca
Mar 7, 2007
  • Mar 7, 2007
Alright, so I'm getting a vibration when I usually reach 50mph. I can feel it through the steering wheel and the front end feels a little loose while driving at a higher speed. What do you guys think is the problem? tie-rods? please help
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 7, 2007
  • Mar 7, 2007
my guess would be the front wheels are out of balance
00BlkStangGT
46
Pleasanton, Ca
Mar 7, 2007
  • Mar 7, 2007
The wheels were balanced about 3-4 months ago. I can't imagine them going out of balance that quickly.
R
razorbackGT
  • Mar 7, 2007
hey man same problem here. You need new front brake pads and your front rotors resurfaced!
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 7, 2007
  • Mar 7, 2007
Brakes or warped rotors would vibrate while braking...not a 50mph.
A warped tire would cause such a vibration...might go ahead and have a tire shop take a look. Sometimes a steel belt will shift and cause warpage.
00BlkStangGT
46
Pleasanton, Ca
Mar 7, 2007
  • Mar 7, 2007
Thanks for the suggestions guys. I'm gonna throw on a different set of tires I have and see if the problem is still there. Then I will know if its the tires. I'll let you know the outcome.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 7, 2007
  • Mar 7, 2007
check the balance. you should rebalance every 3000 miles.
D
Dragstr05
643
Stafford VA
Mar 7, 2007
  • Mar 7, 2007
IMO balancing your tires every 3000 miles is overkill.
Do you feel it in the back also? Rotate the tires, see if the vibration shifts to the back or if it goes away. You said your tires were just balanced. Are the insides of the wheels clean? Something as simple as mud or snow stuck on the insides of the rim can throw balance off and give you this issue. Also, I've only seen this once, but I did have a car with a vibration problem and when I took the wheels off to balance them, there were large accumulations of WATER inside. That was a simple fix.
00BlkStangGT
46
Pleasanton, Ca
Mar 8, 2007
  • Mar 8, 2007
Well last night I threw on my old rims onto the front of the car. I took it for a little drive and didn't notice any vibrations. I guess I'll go get my tires balanced and have them look at my front tires. There isn't any mud or snow on the inside of the rim. I live in Cali. My tires are looking worn on the front so it might be time for some new ones.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Mar 8, 2007
#10
  • Mar 8, 2007
  • #10
Look at the tires closely. Feel across the tread. If you feel sort of a valley then they probably wore funny. It throws the belt out of whack and you get the vibration. It's happened to me with a set of Mastercrafts on my Probe and the cheapo Tire Kingdom knock-offs I replaced them with.
cooper58d2002
98
Hope Mills NC
Mar 8, 2007
#11
  • Mar 8, 2007
  • #11
The pesky lead weights that they slap on the rim of the tire can fall off as well so if you had your tires balanced recently one of the weights the service tech put on could have fallen off. especially if it has a large lip on the edge of the rim most balance weights are designed for stock metal rims and not the larger walled alloy rims.
streethorse
1,042
Dallas Texas
Mar 8, 2007
#12
  • Mar 8, 2007
  • #12
If you have ever had the tires patched after a flat they may never balance
right.... especially if you have 2 patchs on the same tire. I always get plugs
now when I get a flat for that reason.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 8, 2007
#13
  • Mar 8, 2007
  • #13
a patch will not affect balance. i have never seen a tire not balance b/c of a 4 oz patch.
00BlkStangGT
46
Pleasanton, Ca
Mar 8, 2007
#14
  • Mar 8, 2007
  • #14
Well I'm going to go get my tired balanced today when I get off of work. Hopefully that is the problem and nothing else.
fastfive_ogt
23
Wisconsin
Mar 8, 2007
#15
  • Mar 8, 2007
  • #15
edit
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
