Voltage Regulater Wiring
  • Thread starter Thread starter Beastmode54
  • Start date Start date Jan 8, 2007
Beastmode54
14
  • Jan 8, 2007
i just bought my first Mustang..its a 1969 302 Coup. The car runs fine but the voltage reg is not totally connected, Only one wire is connected im not sure where the other wires are suppossed to be connected, the are 3 other places where the other wires can be connected, but i do not know the order. Does anyone know where i can get this info>>>
Thanks!!!!!!!
Cupid
162
  • Jan 8, 2007
Are you sure the previous owner didn't upgrade to a 1 wire alternator? I only ask because you said the car runs fine. If nobody here can answer your question, try the folks over at http://www.1969stang.com/main/. Mainly 69/70 Stangs over there.
Beastmode54
14
  • Jan 8, 2007
I thought ther same...but i found soem extra wires coming from Alternator...and i notive that all the lights are very dim...and eventually it runs the batterary down. And with a voltage tester i determined that the Alt wasnt charging the battery with enough juce. Thanks for the info ill ck the Link out. I also have soem more questions, but ill save those for a later time.
Thanks
Cupid
162
  • Jan 8, 2007
This is a pic of my stock setup. Hope it helps. It's all I have.
Beastmode54
14
  • Jan 9, 2007
Thanks........i think this well help!!!
Tim65GT
1,149
West Texas
Jan 9, 2007
  • Jan 9, 2007
I - The schematic I have for a '69 shows no connection, which is confirmed on the picture of Cupids stock setup.
A - The schematic I have shows Green/Black from the Bat/sol. You have a Yellow wire.
S - Green/Red from Ignition Switch.
F - Orange wire to the Alternator Field.
Beastmode54
14
  • Jan 12, 2007
Hey Thanks guys for the help..i replaced the wires and connectors..and it is working great!!!!!! This site is great!! i cant wait to get more involved, il have to get some pics up 2
Beastmode54
14
  • Jan 12, 2007
x
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Resolved 83 alternator wiring harness
  • sparten5000
  • Aug 2, 2026
Fox 5.0 Mustang Tech Aug 23, 2026
limp
Console wiring plug
  • beerslob
  • Jul 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
apple99Mustangdude
A
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
J
Power Wire Upgrade Question
  • jhaling
  • Dec 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
