  • SN95 4.6L Mustang Tech
Voltage Spike Issue
  • Thread starter Thread starter squares98
  • Start date Start date Jan 19, 2006
squares98
852
Orange,ca
Jan 19, 2006
  • Jan 19, 2006
Tonight my voltage guage basically pegged to the right, causing the battery light to come on
When I start the car the voltage reads about 2v too high, when i touch the gas pedal the guage will peg. I had to turn off my stereo because the subs on the mach 460 kept on loosing/then regaining amp power.
Ive searched on the subject and found topics concerning the voltage regulator inside of the alternator. This does make sense to me. The alternator was always slightly audible but now it has a pretty noticable whine when you tap the gas.
Any Ideas?
also it idles fine and the needle drops down to m on normal but when you tap the gas it swings right just as quickly as the tach.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Jan 19, 2006
  • Jan 19, 2006
do yo have a capacitor for teh amp so the alternator dosent take a hard hit everytime the bass hits, but you need a new alternator
Stangdriver1119
231
Saddle Brook, NJ
Jan 19, 2006
  • Jan 19, 2006
i agree sounds like the alternator...or else something is shorting intermittently if your battery meter pegs for a sec then goes back to normal
squares98
852
Orange,ca
Jan 20, 2006
  • Jan 20, 2006
Well the car is dead this morning which =bad voltage regulator(alternator). Just replaced the battery 1 month ago, but it could be part of the problem.
My question is.. should I replace the alternator with the 04' ford part replacement or the 98 part number replacement. The engine came with the 04 part obvoiusly, but would the 98 maybe work better?
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
A
Electrical '89 GT Fast Drain of Battery - Battery Won't Charge When Connected
  • aroorda
  • May 15, 2022
2K
Fox 5.0 Mustang Tech Jun 3, 2022
Mustang5L5
9
94 5.0L issue with keeping the engine running
  • 94stang5.0L
  • Jun 23, 2020
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 24, 2020
General karthief
J
Electrical No crank no dash no nothing, troubleshooting leads to more questions
  • Jojam99
  • Jun 2, 2022
3K
1994 - 1995 Specific Tech Jun 2, 2022
Jojam99
J
N
Thought I had finally finished the rewire of my 65 coupe...
  • Navyflyer72
  • Aug 24, 2019
2K
Classic Mustang Specific Tech Sep 18, 2019
Navyflyer72
N
