  • SN95 4.6L Mustang Tech
Vortech problems HELP!
  • Thread starter Thread starter J smitty
  • Start date Start date Nov 13, 2008
J
J smitty
32
Foristell Mo
Nov 13, 2008
  • Nov 13, 2008
Ok so I installed my vortech T-trim about a month ago on my 2004 Gt. Took it to the dyno and the tuner uped my fuel a bit because it was running lean I asssume because i bought a plenum and throttle body. After the dyno the car was running perfect. Now after the MPH boost pipe install there is no light on the dash but I checked the DTC on my xc3 and it pulled the code P0190 which is a fuel rail failure or something. Also the reason why i was checking the DTC's was because i got the boost pipe on and the car ran great for about twenty minutes then. the car was in 5th gear and it started surging like pulsing while i was holding a consistant throttle. So i limped the car home and havent ran it yet. There is oil leaking from the pcv valve onto the intake manifld so i checked the oil feed and there was a bur on the 45 degree fitting. Hopefully a metal shard didnt go into my vortech.
did the boost pipe lean the car out enough to throw that code? and why is it not showing on the dash?
And why is it leaking from the pcv valve and the car surging
D
darkside03gt
851
Sacramento CA
Nov 13, 2008
  • Nov 13, 2008
First off I believe that code has to be seen 3 times by the ecu before it will give you a check engine light. that code shows up whenever the fuel rail pressure sensor voltage drops below a certain point. This code could have been stored before you got your car re-tuned. Do you have a wideband on your car to check your AFR? some people need to have there dyno guy tweak there tune once they have added a boost pipe and some are just fine. How did you go from leaking pcv to checking the 45 fitting on the blower? I would be checking the pcv and inspecting the boost pipe to see if there is oil inside of it. Your pcv may have simply failed and is stuck open.
J
J smitty
32
Foristell Mo
Nov 13, 2008
  • Nov 13, 2008
Yeah thanks. I just dont get why the car ran great once the pipe was installed. Now when I start the car it just seems like shaking more than usual? could it be a motor mount? or like the bur from the fitting couldnt of went in the gears of the blower? What would be the symptoms of that?
D
darkside03gt
851
Sacramento CA
Nov 14, 2008
  • Nov 14, 2008
if a burr went into the blower it has probably been chewed up by now. I would disconnect the belt and spin it by hand and listin for anything unusual. its normal to hear a gear mesh sound. I would also re-check you hoses on your boost pipe to see if anything came off or wasnt tightened down enough or plane not installed right. Aslo check you bypass valve too make sure it isnt loose and functioning correctly.
the98stang
2,408
Clovis, CA
Nov 14, 2008
  • Nov 14, 2008
Definitely a boost leak.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Nov 14, 2008
  • Nov 14, 2008
from the factory the codes sets if the fuel pressure is under 28 psi for 8 seconds while at WOT , the tuner probably set this at 38-35 psi for 1.0-1.5 seconds which is what I have seen by several tuners out there when tuning a boosted car , so it can pop up if you powershift the car , watch the gauge and if its holding fine under WOT , erase the code and keep driving .....if its losing fuel pressure you need to check for blockage , bad FPR sensor , vacuum leak , or fuel pump/s going out ..........if it holding pressure and just eronously setting the code at times , get the tuner to set the pressure to 32psi for 2 seconds and see if that will keep it from coming on
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
  • Gulftown980x
  • Jul 29, 2026
squeak93
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
