Wandering Steering
  • Thread starter Thread starter Cam Coppola
  • Start date Start date May 6, 2018
Cam Coppola
38
Ontario, Canada
May 6, 2018
  • May 6, 2018
I've noticed while driving my 95 GT convertible it has a tendency to suddenly steer to the right or left when driving over a bump or a rut in the road. The car drives straight. Does not pull either way and all steering and suspension is tight. Btw car is all original. Is this known as bump steer. Is there a fix for this.
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,949
5,825
213
May 6, 2018
  • May 6, 2018
There's a rubber disc in the steering column under the hood where it connects to the rack. When those rag joints go bad they can cause a drift and loose steering.
They are cheap and in stock at most local parts stores. The steering shaft from the rack to the part under the booster has to come out to replace it.
Of you have someone turn the steering wheel back and forth with the car off you should be able to tell if its bad.
Cam Coppola
38
Ontario, Canada
May 6, 2018
  • May 6, 2018
I will take a look. Thanks
BlakeusMaximus
Still got to try a little lube on my speedo head
5 Year Member
Jul 12, 2017
2,477
1,349
173
May 6, 2018
  • May 6, 2018
Rag joint
General karthief
Mod Dude
Aug 25, 2016
28,094
10,710
213
polk county florida
May 6, 2018
  • May 6, 2018
Rubber looking disc thingy with holes
Reactions: 90sickfox
Cam Coppola
38
Ontario, Canada
May 6, 2018
  • May 6, 2018
BlakeusMaximus said:
Rag joint[/QUO
Not sure what a rag joint is and where its located
Mustang5L5
Mod Dude
Feb 18, 2001
43,346
18,080
224
Massachusetts
May 6, 2018
  • May 6, 2018
I'd say it's either bumpsteer or tramlining. Cause could be a number of things. Alignment specs (too little camber) can also be a cause
Could also be wear and slop in some of the 23 year old bushings...front and rear
Cam Coppola
38
Ontario, Canada
May 6, 2018
  • May 6, 2018
It's drives straight as an arrow. How do we check for bump steer.
Mustang5L5
Mod Dude
Feb 18, 2001
43,346
18,080
224
Massachusetts
May 6, 2018
  • May 6, 2018
http://www.maximummotorsports.com/Bumpsteer-Gauge-P193.aspx
You really shouldn't be having bumpsteer issues on stock suspension parts. Have you physically pulled wheels and put a prybar on various suspension parts to test for wear and tear?
General karthief
Mod Dude
Aug 25, 2016
28,094
10,710
213
polk county florida
May 6, 2018
#10
  • May 6, 2018
  • #10
I didn't read the entire article but this should help explain 'bump steer'
https://en.wikipedia.org/wiki/Bump_steer
You get a similar steering sensation when frontend components are worn, they may look and act fine but exert the forces of driving and things move around, a lot.
Cam Coppola
38
Ontario, Canada
May 6, 2018
#11
  • May 6, 2018
  • #11
I have not. Didnt think anything could be wrong with suspension with how straight the car drives. I will look at that too. Thanks
Reddevil91
1,630
773
163
May 7, 2018
#12
  • May 7, 2018
  • #12
So is that rubber thing you all are talkIf about what causes the fox body to have so much play in the fox’s? Feel like in my 91 I can be driving straight and I have so play left and right without making the car shift. I guess that why some ppl buy the flaming river or MM shafts? If so, can you use these on stock rack?
MFE92
1,094
373
124
Phoenix
May 7, 2018
#13
  • May 7, 2018
  • #13
Following ruts in the road is called "tramlining", and these cars are terrible for it. The wider the tires, the worse it is. The more they wear to the inside, the worse it is.
I
I only know what I know
88
Michigan
May 7, 2018
#14
  • May 7, 2018
  • #14
Just some additional thoughts from what has been suggested.
When you say "suddenly steer" that suggests the steering wheel is turning along with the sudden change in direction. Is that correct? Or does the steering direction change without any change in the steering wheel? Have you noticed if accelerating alone will self correct the steering or do you have to use the steering wheel to right the steering?
Are you braking because of the bump or rut when this happens? If so, do you know what happens if you're not braking?
Finally, not knowing where you live is there a chance you are facing up or down hill when this happens or are you on level ground?
Mustang5L5
Mod Dude
Feb 18, 2001
43,346
18,080
224
Massachusetts
May 7, 2018
#15
  • May 7, 2018
  • #15
Rag joints wear out and get sloppy. Their purpose is to numb the steering wheel from every little road inperfection. Easy way to tell if yours is bad is to stand next to your car and wiggle your steering wheel and watch the front wheel. If you can rock it pretty well without the front wheel moving much, prob might want to replace it. They sell them in the help aisle at autozone.
I have the MM shaft and there is no rag joint. Move the steering wheel a tiny bit and you can see the front wheel move immediately. It terms of feeling all road imperfections it's not that bad. I did my own alignment and dialed in a bit more caster to help combat tramlining. At highway speed it's pretty steady
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
