Well, I just finshed installing a carb yet again and I get it running just fine. It was running around 10 minutes so it was warmed up. Fan went off and on twice while I was at it. I climb in and the cabin is filled with "smoke". This is fairly normal with this car but it is coming from the windshield vents. Ok I say, whetever.
I go to pull out and BOOM!!
I thought that all the gas splashed on the intake just went up but the incredible amount of steam made me realize I was puking the contents of the cooling system. I mean it was spectacular!! I filled the whole backyard in under 10 seconds. I tried to fling it in gear into the garage in it's final gasps. But no go and shes sitting outside. I crank it and it's real real real slow like it's fighting something.
While it was still geysering, I ran out and confirmed the location of the geyser was between the WP housing and TC cover behind the paired passenger side coolant hose fittings on the pump. So it was a gasket blow around the PS of the waterpump.
The WP is an 83 tbird 302 WP. This is std rotation right??? I'm not losing my mind am I? I have it belted for std rotation. I hope I'm not running the pump backwards.
It ran without hitch last weekend though I DID see that wierd smoke from the dash.
Question? Which of those fittings is a "return line"? I have the 2 WP fittings hooked to either side of the trans cooler I use as a heater. Are they feed/return or are both returns or both feeds?
Did my thermostat seize?!? This is so wierd! No problems last weekend circling the block for almost an hour. Any thoughts good gentlemen? Did I hydrolock my car? I check pluged #1 and it looks clean.
