wats compatible
  • Thread starter Thread starter tbfastr
  • Start date Start date Apr 7, 2006
T
tbfastr
  • Apr 7, 2006
hi im swaping 8 into an 4 cyl set up car.i dont have a trans and was wondering if anyone could tell me wat would fit in ther and wat i could get it out of.(besides a mustang)??thank you i need all the help i can get. by the way the cars a 93.thank you , tbfastr
J
Jack's95gt
443
Huntingdon Valley, PA
Apr 8, 2006
  • Apr 8, 2006
I did a 93 a few months ago.
Here's a list of the things that must be changed.
Engine - not one thing on that entire 4 cylinder engine can be used with the 5.0, except maybe the PS pump.
Headers - h pipe - cat backs - O2 sensors - O2 hardness - all exhaust hangers - passinger side rear brake line must be modified - fuel lines, there on the wrong side - engine computer - main wiring hardness - injector wiring hardness - Coil - If auto, it won't fit, need AOD or C4 - auto shifter - tranny cooling lines - hoses - stock electric fan won't fit - radiator over flow bottle - MAF - Engine and tranny mounts - alternator cables must be lenghten, good time to change to a 3G alternator - all accessory brackets - driveshaft - gauge cluster, tach will be wrong - throttle cable - cruise control servo, 4 cylinder cable too short- power steering return line. The radiator is the same, but it's a good time to switch to a 3 core.
I already had a 5.0 long block that I rebuilt. It still it cost me between $2500 to $3000 in parts purchases. Most of the items I bought new. I left the 7.5 rear, but installed a locker carrier from a Ranger and it's holding up well. The 4 cylinder cars have 3.73 gears to get them moving. So far it's holding up. The 4 cylinder brake system is doing a fine job stopping to.
It would have been much easier and less expensive by buying 5.0 wreck and using it as a donor car.
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
