wats detonation?
  • Thread starter Thread starter DirtyD916
  • Start date Start date Jun 10, 2004
DirtyD916
804
Norcal 916
Jun 10, 2004
  • Jun 10, 2004
Wat exactly is detontation? when does it occur? what does it sound like? how do you prevent it?
HISSIN50
34
129
Jun 11, 2004
  • Jun 11, 2004
detonation (and preignition) sounds like marbles inside a jar, rattling around.
it can be from the mixture lighting off on its own or from leanness, too much timing, heat, C.R. being too high, low octane fuel, carbon build up in the chambers, etc.
prevention: to treat the symptom, you can back timing off or run more octane. those are the most common. keep the chambers clean.
for a little more info, try readin some of this:
http://forums.stangnet.com/search.php?searchid=424697
Jrichker has a nice little write up - you should find that post in one of those threads...
good luck
HISSIN50
34
129
Jun 11, 2004
  • Jun 11, 2004
actually his post was in there; here it is:
http://forums.stangnet.com/showpost.php?p=3816521&postcount=6
stang_gt_1994
2,723
Powder Springs, GA (30 min. from Atlanta)
Jun 11, 2004
  • Jun 11, 2004
What is a dictionary? J/k 94-95 GT's are more prone to this also. Iron heads are also more prone.
G
GATOR98GT
185
BRISTOL
Jun 11, 2004
  • Jun 11, 2004
this is it
bmorrisj
449
Buena Park, CA
Jun 11, 2004
  • Jun 11, 2004
what happens when you force a shrinking cylinder open....(force a compressing piston down).....the piston and rods (weakest link) take the brunt of the force...so sooner or later somethings gotta give....
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
