weight
most street foxes tip the scales at about 30-3200lbs and they can be taken down way lower than that
my friends carbed notch had a race weight of about 2800lbs and all he did was a little basic weight reduction
AndyG47 said:
I must have been reading the sticker wrong in my car then cause it says it's over 4000 pounds.
the sticker in the door or whereever is the GVWR
which means basically, the car with a full tank of gas, all the fluids, and carrying all the weight that that car can legally carry
so that number is very blown up
If you're close to an interstate, why not just pull into one of the semi-truck scale houses? They'll be able to tell you, I've done it before at around 4:00 am, but I was driving a crown vic at the time, so I can't help you with the weight on a stang
Are those places even open in Ohio? In every weigh station in PA/NJ/DE they are all closed down.
My guess would be a recylcing plant.
