Weird Brake Light Occurrences
billison
I like tinted tail
2,607
1,094
184
stl
ok, short back story incase your not following my
Build. Finishing my wire tuck, installed cobra booster, and tail lights are not installed incase that matters.
Got the electrical hooked up to do basic testing. Brake lights and hazards didn't work. Bad fuse (15amp) , changed it, hazards work, brake lights work for a few pumps then fuse pops. Tossed a 20a fuse in ( I know, bad idea) and did a test, they worked, then they flickered ( getting brighter not dimmer) and went to proper brightness ( was dim before but didn't realize )'and I see a small puff of smoke. I stopped, checked the harness and everything seems fine now... the rear light harness was just laying there..
My best guess is something was touching something
Puff of smoke from where ? Where there's smoke there's.....fire !
You need to check that circuit. The power wire and the ground needs to be checked for shorts.
Sorry, should have explained that batter.
The smoke came from near the rear tail light harness. The harness was laying in the rear. So far it looks like part of the harness was contacting the frame somewhere.
