weird noise
  • Thread starter Thread starter 07alloytoy
  • Start date Start date Oct 16, 2007
07alloytoy
Bethel, CT
Oct 16, 2007
  • Oct 16, 2007
Hey all. I have a weird noise coming from either my dash or engine. It only happens when I get on the gas. The only way to describe it is like grains of sand lightly hitting something in the engine bay. No it isnt sand. From what I was told pinging is a more noticable marble clunking sound but not sure if thats true. Any ideas?
gashog
139
Fresno, CA
Oct 16, 2007
  • Oct 16, 2007
It sounds like something vibrating, a heat shield maybe? I had a wierd noise on another car, and it turned out to be this.
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Oct 16, 2007
  • Oct 16, 2007
I have a similar sound coming from the rear end. Noticed it after my last trip down the strip the other night. I'm sure it's different though.
Jenns01TA
37
Oct 16, 2007
  • Oct 16, 2007
I seriously doubt it is knocking or pinging since these engines have a knock sensor which communicates with the ECU and when detonation issues are encountered the ignition timing is retarded, reducing the knocking and protecting the engine. Any driveability issues when you hear this sound?
Next I would think it may be intake or valve lash sounds you are hearing. But the "sand" comment throws me a bit. Vacuum leaks can cause a crackling sucking sound which could become less obvious inside the car. Valve lash clearance issues will sound wet and more metallic.
If it is inside the car, it could be something with the instrument cluster. Next time you get on it - peek at the tach and see if the needle is dropping as expected or sticking. Same with the MPH gauge.
Sorry I can't be of more help without hearing what you are hearing.
07alloytoy
Bethel, CT
Oct 17, 2007
  • Oct 17, 2007
thanks for your replies. I think it may be the gauge cluster, not sure if its causing any damage because everything is working well. I forgot to mention my mods though I don't think they have anything do do with it.
Roush cai with performance 93 octane tune
Bassani X pipe and Bassani axle back mufflers
Jenns01TA
37
Oct 17, 2007
  • Oct 17, 2007
Happy to help. I had a similar sound in the gauge cluster of my V-6. Came from the tachometer. It was annoying yet harmless. Tach needle was stickie past 4,300 RPM bounc back from WOT made it sound like BBs tinging in the cluster.
K
Kilmar
68
  • Oct 18, 2007
I have a similar, if not the same, sound. It is the center dash rattling. The molding is very loose and it's not even screwed in. Most of the interior molding is held together by thumb screws. And you thought imports had it bad.
Next time you hear the sound, put your hand on top of the center dash and push down and see if the noise disappears.
07alloytoy
Bethel, CT
Oct 18, 2007
  • Oct 18, 2007
will do thanks!!!!!
K
kkdoughboy
212
Pennsylvania
Oct 18, 2007
  • Oct 18, 2007
Did you switch out your shifter to a shorty? My car has a slight vibrating on metal noise only at certain times. When I put my hand on the shift knob tightly it stops. Once we start messing around with aftermarket parts the noises start. Get an exhaust to forget about that problem right away!!!!
R
romancer
25
#10
  • Jan 7, 2008
  • #10
Old thread, I know...
I searched and am bumping this because I have noticed the same exact thing, tonight. Sounds like it is coming from either the top of the engine or from the dash. 07alloytoy, did you find out what the problem is? It only seems to happen above around 4k rpms. Seems like the dash from what I'm hearing.
God Bless,
SpartaPerformance
2,517
61
89
Long Island NY
Jan 7, 2008
#11
  • Jan 7, 2008
  • #11
HHmmmmm now that you added your mod list, I'm leaning towards pinging!!! Easy test.....install the 87 octane tune while still having the 93 fuel and see if sound goes away.
R
romancer
25
#12
  • Jan 8, 2008
  • #12
Don't think it's pinging. I have a Shelby GT and I have the same issue. I highly doubt I'd be pinging with no work done to it at all. I run 93 only. Think it may just be the heat shield. No affect in performance at all.
God Bless,
What is this noise?!
  • squirrel0420
  • Jul 3, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 4, 2025
horse sence
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
