Weird problem
  • Thread starter Thread starter strtrcr50
  • Start date Start date Aug 20, 2007
strtrcr50
Previously from Dirty Jerzey exit 7a
Aug 20, 2007
  • Aug 20, 2007
If I let my car sit for over 5 hrs, upon restart it starts fine, then the idle drops quickly till it stalls. It also loses all the preprogrammed radio stations at that time and goes to am 600.(factory radio) When I start it back up, it's fine with the exception of a lot of popping out the exhaust pipes for 2-5 minutes. I can turn it off and wait an hour or so and have none of these problems. Only when I shut it off for a long time.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Aug 20, 2007
  • Aug 20, 2007
have you checked to make sure its charging properly?
strtrcr50
Aug 20, 2007
  • Aug 20, 2007
I'm not sure that it is. I've been having the temp gauge acting up depending on the electrical load. But all I do is restart and I'm good to go with the other problem. It does crank fast and start fast on that first cold start.
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Aug 20, 2007
  • Aug 20, 2007
sounds to me like you are having a charging issue.
strtrcr50
Aug 20, 2007
  • Aug 20, 2007
You think? The battery should be in worse shape on the second start, right?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 21, 2007
  • Aug 21, 2007
See "Surging Idle Checklist for help with all your idle/stall problems. The first two posts contain all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
Part of the Surging Idle Checklist tells you to dump the codes. When you do, look for code 15, no KAM voltage.
strtrcr50
Aug 22, 2007
  • Aug 22, 2007
For codes, I get an 11 for key on engine off, and a 33 for continious memory. I don't have a surging idle. Just the first stall. Then on restart and unless the car sits for a long time, it is perfect. Today when I went out to start the car, it had lost radio memory and I figured it would do the same thing. I pulled codes to see what was stored which required cycling the key and it was fine. However, the first time, it wouldn't pull codes. I had to cycle the key and start over a second time.
HISSIN50
34
129
Aug 22, 2007
  • Aug 22, 2007
If the EEC relay doesnt energize, you cant receive codes. That might also play into the stalling and memory loss (bad solenoid connection or some goofball anomaly that I'm not smart enough to figure out).
ls1beater4eva
334
mooresville
Aug 22, 2007
  • Aug 22, 2007
check your ground strap that goes from the back of the head to the fire wall and the ground wire from the injector harness to the back of the head allso , taking a look at the the battery ground wire wouldnt be a bad idea either
strtrcr50
Aug 22, 2007
#10
  • Aug 22, 2007
  • #10
I'll try to check the eec relay and grounds. Thanks.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
  • Mindseye007
  • Aug 16, 2026
Mindseye007
