Went to the dragstrip
jhonda
125
Huntersville NC
Went to zmax dragway last night.....longstory short track sucked. Best time was
2.2 60ft
9.0 1/8th
81 mph
13.802 1/4
104mph
Mods were gutted hatch, removed passenger seat, cobra intake manifold, offroad x, magnaflow catback, udp, c&l maf, eibach prokit, street tires 275/40/17s summoto hrzIII
dynoed 225whp 270wtq SAE corrected
If I could hook what should I be running?
Not sure how good of a 60 you will be able to get out of your low pro street tires. But, with a set of 15" wheels and slicks or drag radials if you can get a 1.7 out of it 104mph is good for 12s. Throw in the driver mod and you should have a solid 12 sec rig.
2.2 60ft
9.0 1/8th
81 mph
13.802 1/4
104mph
Your times and dyno numbers are very similar to mine but your Fox is lighter so you should be doing better. With your 104mph trap you should be nearer 13.1 and nearer 8.4 to the 1/8. You're definitely losing time off the line and the biggest reason is probably the street tires. Better rear lower control arms also help get the power down.
