Went to the strip today...Good & Bad news
coolblue65
1,224
Algonquin, IL
First the Good news, I was finally able to get my drag radials (235 BFG's) on and get to the track, and I really improved my times, although I still have a lot to gain in my 60'.
1st Run
(20 PSI in tires)
R/T ... .200
60' ... 2.034
330 ... 5.438
1/8 ... 8.263
MPH ... 88.83
1000 ... 10.694
1/4 ... 12.757
MPH ... 109.60
2nd Run
(18 PSI)
R/T ... .273
60' ... 2.021
330 ... 5.404
1/8 ... 8.240
MPH ... 88.39
1000 ... 10.667
1/4 ... 12.746
MPH ... 108.86
So the bad 3rd run, I never left the line because my custom made 3.5" drive shaft decided to let go: :mad:
It looks like it was just welded poorly, thoughts?
Funny thing is I'm not to mad about it breaking because I have finally started to get some respectable times.
Good times on the runs!
The welds look like they did not have good penetration.
My aluminum shaft has welds that are twice as wide as the one in the pictures. It is made by Coleman and sold through Street or Track in any length you need for $299.
Here are pics of it on my webpage: Drive shaft.
Good Luck and Be Safe
Ron
The times are good. That sucks about the failure. Whose driveshaft is it?
I had the driveshaft made by a local driveline shop. Its been awhile since I bought it, and there is no warranty that I remember, but I am going to take it into the shop this week and show it to them and see what there response is, as it appears that the failure was 100% a result of their workmanship.
Nice times.
I did just realize that I have been spending to much time in the off topic sections. Because it took me a minute to realize what type of strip you were talking about when I saw the title...
Nice times. Judging by your 109 trap speed you have low 12 sec capability. Just need more practice on the BFG's. When you starting hitting 1.8x's or so 60 times those ET's will be a droppin. I can't recall what Trans you run. Stick or Auto? Again nice times, sorry to see the carniage.
1st Run
(20 PSI in tires)
R/T ... .200
60' ... 2.034
330 ... 5.438
1/8 ... 8.263
MPH ... 88.83
1000 ... 10.694
1/4 ... 12.757
MPH ... 109.60
2nd Run
(18 PSI)
R/T ... .273
60' ... 2.021
330 ... 5.404
1/8 ... 8.240
MPH ... 88.39
1000 ... 10.667
1/4 ... 12.746
MPH ... 108.86
these are good numbers, and quite consistent. i would like to see your 60ft times closer to a high 1.8 range though, but i think you will get there in time.
the weld looks like a cold weld with very little penetration.
Thanks for the positive comments, I have been waiting for a long time to start getting some decent times on this car (considering all the money spent!) its also a nice pride booster that I can smoke my old man's C5 Vette!
I would like to see myself in the 1.8's too, I was really hoping to get into the 1.9x's on Monday. Out of curiosity how does a .1 second improvement in '60 translate to the 1/4 ET?
ga289stocker- I run a Tremec 3550, it has the lower 3.27 first gear ratio instead of the 2.98, and I have 3.55 rear gears.
Maybe 2 tenths, maybe more. That MPH is a good sign. That's good for low 12's definitely, 11's if you drive like you stole it. Would imagine low 1.7, even 1.6's might be possible with good traction
Weird you broke with those 60's though. Second time I have seen an AL DS go with 60's in the 2.0's. hmmm
Agree, should run 1.7's with no issues with those times. 1.8's or slower are, well slow for those et's/mph.
Way to dip into the 12's! It's always a plus when you beat your previous best.
2.0 second 60's are way slow for a 12.7 et. Sounds like you need to launch much harder. Well, when you get a driveshaft that will hold up.:nice:
That sux about the driveshaft. Nothing should ever break with over 2 second 60 footers. Bad weld! Bad!:D
now i am just debating if i should put my steal driveshaft back in with new u-joints and run it for awhile, or if I should spend $400 and get a new drive shaft right away.
Vinyl66- It was only my first time on the drag radials and I really wasn't sure how to launch it. My last clean run I had the tires at 18psi, i did a fairly short burn out, and was holding ~3000 RPMs at the line, after the light goes green I didn't get 100% into the throttle until I was already rolling for a bit (I think that is a habbit I got into because of my street tires and them breaking loose at low speeds with full throttle). Long story short, I have a lot to practice.
If you're going to the drag strip, get a suitable driveshaft. If you're just going to cruise around town for a while, a stock driveshaft should be fine. For drag racing, esp. when using sticky tires, I like to use a well made steel driveshaft with a safety loop. Denny's driveshafts is one of several places that makes a good quality piece--for the reason listed below, from their website.
"We stand behind all of our Heavy Duty driveshafts....so remember "IF YOU EVER TWIST OUR TUBING OR BREAK OUR WELDS...WE'LL REPLACE IT FREE!!!"
So was that a shortened aerostar driveshaft? Looks too clean to be a used piece?
If it was an aerostar shaft, it's nice to see that even in the 12's, it was the weld that let go instead of a twisted tube.
