went to the track
  • Thread starter Thread starter 93notchspray
  • Start date Start date Apr 18, 2004
9
93notchspray
87
blacklick ohio
Apr 18, 2004
  • Apr 18, 2004
went to the track today nnot very happy. i have a 93 notch with x-pipe flowmasters 4:10s et streets electric fan bbk fuel regulator cai hooker headers 190 pump. my et were 1st run 2.012 60, 14.064 98.04 mph 2nd run with 150 shot in 3rd only 2.004 13.03 103.63 i think my problem is i have no line loc let me know what you guys think thanks jason
sirr0bin
174
Winnipeg, Manitoba
Apr 18, 2004
  • Apr 18, 2004
you only used nitrous in 3rd, and you ran a 13.03 with the mods listed?
i'd be a happy man if i ran those times with those mods
TT91
1,536
Paramus, NJ
Apr 18, 2004
  • Apr 18, 2004
How is not having a line lock the problem, my car runs 10s without a line lock....its about modifacations, and the only one working on your side are those 4.10's. most guys with manuals dont use line locksoff the line, it just takes practice and good control. what gear did u trap in> 4th im hoping with 4.10s. Anymore more info u can provide about the pass?
NeQX
904
Infront Of You, NY
Apr 18, 2004
  • Apr 18, 2004
Peel out longer, and launch harder, you should be cutting 1.7's or better with ET streets, set up window switch for n2o, and launch with it also, guarantee you low 12's
Badlilstang
1,606
Spring , Texas
Apr 18, 2004
  • Apr 18, 2004
IF you were on ET streets you should be cutting much better 60fts with that gear in that light of a car. Drop tires down to 11lbs of air pressure.. do a solid burnout by power braking the car.. when they start to smoke good lift off the brake and keep your foot in it until the tires bite/chirp. Take it and hold it at about 4k rpm and when your ready to launch put your foot down to the floor and then lift off the clutch around 5K rpm. Your car should be well into the 13s on motor alone. When you really want to run fast on nitrous use a full throttle switch and spray it right off the line in first gear. You will want to leave a little lower rpm when spraying. Driving can make a world of difference and getting that 60ft down some will help for sure. When I was 16 I ran a 14.04 in a 12 second GTO my first time ever at the track lol.
9
93notchspray
87
blacklick ohio
Apr 18, 2004
  • Apr 18, 2004
i think the problem is that im not staying in the burn out box long enough. the line loc would help me stay in the box longer. not for off the line. i also have a full throttle switch and a window switch set for 3k to 6k. i basically put my car in the box put in 2nd gear and dump it trying to hold the brake but it doesnt want to stay. thanks guys anyone other suggestions.
M
mustangrfast88
330
middletown ohio
Apr 18, 2004
  • Apr 18, 2004
what track are you racing at the reason i ask is i live on the ohio border when i am at my moms and i race 2 of the ohio tracks and you should be able to power brake your 5 speed and your car shouldnt just push you i got 4 cyl brakes on my car on i sit in the burn out box for a min or longer and i dont get pushed out of the box
what_stanger?
I am the mailman!!
1,697
Northern Illinois
Apr 19, 2004
  • Apr 19, 2004
heh, with ET streets i'd have that 150 shot outa the hole!!
and every gear thereafter!
Badlilstang
1,606
Spring , Texas
Apr 19, 2004
  • Apr 19, 2004
your not burning out IN the water box are you? All you want is one good tire rotation in the water then pull up out of it a few feet. Disregard this if you arent burnig out IN the water box.
9
93notchspray
87
blacklick ohio
Apr 19, 2004
#10
  • Apr 19, 2004
  • #10
no i dont burn out in the water i pull out. but im telling you my brakes wont hold me in the box. i race at national trail also. little more about my car, i have my timing at 10 degrees and have 24 spark plugs also am running about 40 psi fuel pressure. just wondering if any of this stuff could be hurting it. what about if my posi unit is going out. thanks guys
Badlilstang
1,606
Spring , Texas
Apr 19, 2004
#11
  • Apr 19, 2004
  • #11
Thats really odd you cant power brake that car.. ive driven over 20 mustangs and never had a problem holding one still. Get the tires in the water and try to spin them one rotation.. pull up a few feet.. stop the car.. then rev it up in 2nd gear and dumb the clutch and grab the brake quickly and apply enough pressure to hold the car but not bog the motor. Some ppl like to hold thier foot sideways to power brake. Its all preference but you should be able to hold it still and if not you need to get your brakes checked.
T_5.0_N'works
260
Texas
Apr 19, 2004
#12
  • Apr 19, 2004
  • #12
I have the same problem. I cut 1.9's though with a stock 3.08 rear gear and ET's. I hoping with 3.73's I can get it down to 1.7's. It's not that I'am not warmign my tires up cause I have NO LOSS of traction when I launch at 4-5k. It just bogs and I have to learn to do a hard feather with it.
mustang88GT
186
Charlotte, North Carolina
Apr 19, 2004
#13
  • Apr 19, 2004
  • #13
i have real big prob with my 60 ft with DRs i am only cuting 2.0s and i heat the hell out of them... launch at 4k and it still spins a little but i still run a 8.9 in the 1/8... once i get some sub frames i am going to get some slicks
9
93notchspray
87
blacklick ohio
Apr 19, 2004
#14
  • Apr 19, 2004
  • #14
alls i can do is practice im going back this sun. so iwil try a few different things, hopefully the results are better. thanks jason
Badlilstang
1,606
Spring , Texas
Apr 19, 2004
#15
  • Apr 19, 2004
  • #15
lol I bet it does bog with 3.08 gears... man those 3.73s are gonna be like night and day difference... gonna feel like you stuck nitrous on the car.
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
Fox Kandi: she's cheap, fun, & has a loose top - sold!
  • FastDriver
  • Apr 20, 2019
  • 4 5 6
21K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2019
2000xp8
J
2016 Mustang Gt Auto With 3:55 Rear Track Times...
  • jelsis
  • May 26, 2016
  • 2015 - 2023 (S550) Mustang -General/Talk
2K
2015 - 2023 (S550) Mustang -General/Talk Jun 5, 2016
echo7
Pb At Track Last Night
  • RangerJoe
  • Aug 1, 2015
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2015
FastDriver
Fox Fox Body W/ Cai, Ud Pullies, & 4.30 Gears At The Track
  • FastDriver
  • Jul 13, 2015
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2015
FoxMustangLvr
