What Cfm Needed?
  • Thread starter Thread starter JimmyDoLittle
  • Start date Start date Aug 20, 2016
J
JimmyDoLittle
  • Aug 20, 2016
Just got me my first mustang..67 with a 302(org 289)..The carb is 750cfm..am told that is to much..What is the correct cfm for this eng? Thanks..
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Aug 21, 2016
  • Aug 21, 2016
Probably on the big side unless your a drag racer and your car is set up for it. Original carbs were around 480cfm IIRC.
We would need to know more information about any changes that have been done to the motor, the car, and what you expect out of the car in order to give you a better answer.
J
JimmyDoLittle
  • Aug 21, 2016
Thanks Dennis, I'll get more info as I get more aquainted with it. The PO had it only 2 months and knows nothing..I think I'll keep the 302 as long as it behaves but gotta get the right carb on it..Will 600 CFM be ok?
what does IIRC mean?
dennis112
1,561
36
79
Aug 21, 2016
  • Aug 21, 2016
Is you just want a simple answer, I'd say a 600 Holley with vacuum secondaries would work for you. If your car has an automatic, look for one that has the correct transmission kick down linkage for a Ford.
IIRC is short for "If I Recall Correctly." Its often used on social media when the details were once known, but over time from lack of use get fuzzy in the memory.
D
Dirty Rod
22
  • Aug 21, 2016
I had a 600 on mine until I went to bigger valves and a larger cam and then a 650 worked better.
rbohm
6,698
550
204
tucson,az
Aug 21, 2016
  • Aug 21, 2016
i need to know more about the engine combination before i can give you a proper recommendation.
1: what cam is used
2: what intake
3: what heads, and are they ported
4: what exhaust manifolds/headers
5: what compression ratio
zookeeper
3,415
63
109
Rogue River, Oregon
Aug 22, 2016
  • Aug 22, 2016
Just a little personal experience: I've used 600 cfm, vacuum secondary Holleys on lots of smaller (289-351) engines for years and have been happy. When I changed my car over to a single 4 barrel a couple years ago, I did some research and found QFT carbs. They're essentially a Holley-type carb but better. They aren't all that much more cost-wise and I'm thrilled with mine.
J
JimmyDoLittle
  • Aug 22, 2016
Thanks for the reply rbohm..the engine is a factory 302 out of a wreck with nothing built..long headers..don't know bout the intake nor comp..I have a fairly new 600 Quik Fuel sitting in the barn..Should this fit the Intake on it now?
J
JimmyDoLittle
  • Aug 22, 2016
Yeah, I have a QF sitting on the shelf I will try..Thanks Zoo
Bullitt347
I have been doing it wrong this whole time
4,020
3,017
204
Middle of Maine
Aug 22, 2016
#10
  • Aug 22, 2016
  • #10
It is all in how the carb is set up not so much the size of the carb. I could get a 1bb carb to work good on that engine, I could also get a 900 plus cfm carb to work good. It is about metering the fuel for the amount of air coming in, regardless of the cfm rating of the carb. All that being said...a smaller carb is easier to get to work right. So if you have the ability, the 750 cfm carb that is on the car can be made to work just fine.
rbohm
6,698
550
204
tucson,az
Aug 22, 2016
#11
  • Aug 22, 2016
  • #11
since the engine is basically stock, i would go with the 600cfm carb you have instead of the 780. and both cars will fit the intake since they use the same bolt pattern.
Edbert
3,548
32
109
Austin TX
Aug 24, 2016
#12
  • Aug 24, 2016
  • #12
I've got too much carb on a stout (420+ HP and TQ) 351W. My 750cfm had to be set pretty lean to get a good idle
J
JimmyDoLittle
#13
  • Aug 24, 2016
  • #13
Great Info..thank Y'all !
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
C
93 Tubular A Arm Bushings
  • Chrispy62
  • Jul 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 31, 2026
Chrispy62
C
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
D
Early ford 302 heads
  • Dagasser
  • May 4, 2026
  • The Welcome Wagon
The Welcome Wagon May 4, 2026
