  • SN95 4.6L Mustang Tech
What Clutch?
  • Thread starter Thread starter Firas
  • Start date Start date Mar 24, 2012
Firas
21
Richmond, VA
Mar 24, 2012
  • Mar 24, 2012
It's the time to get the clutch replaced. I'm looking for a good and reliable clutch for my stock 2004 GT.
Any recommendations?
joshjwc9
1,095
17
39
Palm Harbor, FL
Mar 25, 2012
  • Mar 25, 2012
For a stock car that won't be boosted anytime soon. Take your pick from the 03/04 Cobra clutch, RAM HDX or Centerforce DF or the Exedy Mach 400 all seem to be dependable for stock power levels. Just run a Ford TOB and Pilot Bearing too. Also, I'd run the MM Aluminum clutch quadrant as well.
Firas
21
Richmond, VA
Mar 25, 2012
  • Mar 25, 2012
Thanks Josh for the feedback.
So here what I'm getting:
1) Exedy Mach 400 Stage 2 Clutch (Late 01-04 GT, Mach 1; 99-04 Cobra)
2) Ford Racing Roller Pilot Bearing (96-10 4.6L)
3) Ford Racing Performance Throwout Bearing (79-04 V8)
4) Maximum Motorsports Aluminum Clutch Quadrant (79-04 All)
Firas
21
Richmond, VA
Mar 25, 2012
  • Mar 25, 2012
Hey Josh, if you have to chose between HDX and exedy, which one you go with?
And do I need to replace the cable? Any recommendation?
Thanks
vertigasen
366
18
29
Falcon, CO
Mar 25, 2012
  • Mar 25, 2012
I would say the Centerforce DFX. The other stuff looks good, but swap the clutch quadrant for a UPR triple version with the firewall adjuster. It is only about $15 more for the kit and will provide all the adjustment you will ever need. Also, the UPR version has has rounded edges where the clutch cable goes in the quadrant.....it can save some wear on the cable. As for the cable....keep the stock one. If you do need a replacement, get a stock replacement. It is by far the best. I have seen too many "adjustable" clutch cables snap.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 25, 2012
  • Mar 25, 2012
I've always liked the FRPP King Cobra. Nice soft pedal (Centerforce Dual Friction is soft, too), holds a pretty decent amount of power, and doesn't set ya back too much.
joshjwc9
1,095
17
39
Palm Harbor, FL
Mar 26, 2012
  • Mar 26, 2012
I'm a RAM guy. I've run a Powergrip for almost 60k miles both supercharged and NA. I'd pick the HDX over any of those. Although, I hear great things from the Centerforce and Exedy has been in the clutch game for imports forever. I would flip and coin and do some research until you feel comfortable with either.
Stay with the stock cable. I've been there with a UPR cable and it snapped in less than 6 months. Stay with a quadrant that only has one hook. The MM has been engineered perfectly. The Steeda double hook and UPR triple hook each can stretch out a cable prematurely if you have it on the incorrect hook. So, staying with the MM or speed release versions from UPR/MM/Steeda/AM will allow the cable to have the correct amount of slack without overly stretching it out.
trinity_gt
3,125
81
99
Canada
Mar 26, 2012
  • Mar 26, 2012
For a stock car I'd go OE Ford or equivalent. Why go "Stage 2"? Also, why monkey around with the quadrant?
joshjwc9
1,095
17
39
Palm Harbor, FL
Mar 26, 2012
  • Mar 26, 2012
There isn't grand difference in prices or pedal feel. Stage 1 or 2 aren't really much of a killer driveabilty-wise. The stock quadrant has been known to explode...I just wouldn't go with the one that has copied everyone else..
Firas
21
Richmond, VA
Mar 26, 2012
#10
  • Mar 26, 2012
  • #10
Thanks for all who replied. Your feedback definitely will help in deciding what to get.
I'll keep you all posted
Firas
21
Richmond, VA
Mar 30, 2012
#11
  • Mar 30, 2012
  • #11
OK, I visited American Muscle and ended up spending a lot of money
  • Exedy mach 400 clutch
  • MM quadrant
  • K&N CAI
  • Fuel Filter
  • FR Pilot bearing
  • FR Throwout bearing
  • 130 amp alternator
  • Optima yellow head battery
  • Rear Mud Flaps
  • Mach 1 chin spoiler
  • Bumper insert
  • Floor mats
  • Mach 1 shift knob
  • Short Antena
Again thank you all
fshawn50
161
Houston, TX.
Mar 30, 2012
#12
  • Mar 30, 2012
  • #12
All sounds good.
But " MudFlaps"?
Firas
21
Richmond, VA
Mar 30, 2012
#13
  • Mar 30, 2012
  • #13
fshawn50 said:
All sounds good.
But " MudFlaps"?
Yeah you can call them paint protectors
T
Drivetrain Take a look at this clutch pedal
  • TNmach1
  • Sep 18, 2026
SN95 4.6L Mustang Tech Sep 18, 2026
TNmach1
T
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
