What could cause this problem ???
  • Thread starter Thread starter vpap1
  • Start date Start date Oct 13, 2009
V
vpap1
109
  • Oct 13, 2009
1990 mustang gt. Has 99 k, has edelbrock intakes, cold air intake, BBK headers, Flowmaster H pipe and mufflers. T 5 tranny
What could cause this problem , three vids 5 min total , checked tps, ect, acs, maf, aic everything. I need help. Also do you think its cammed, car came with no papers....
V
YouTube - 1990 Mustang 5.0 Cold Start 1 #1
YouTube - 1990 Mustang 5.0 Cold Start 2 #2
YouTube - 1990 Mustang 5.0 Cold Start 3 #3
Thank You
1993SSP
1,194
Ky
Oct 13, 2009
  • Oct 13, 2009
I had the same problem once, it turned out to be the IAC on the front of the throttle body, you can take yours off, there will be 2 round holes, you can trim the part out of the gasket or grind down the metal between the 2 holes and see if that helps, it solved my problem.
Repostyle
538
Portland, OR
Oct 13, 2009
  • Oct 13, 2009
I had the same problem with my 91. Turned out to be a simple fix, I had left a hose clamp loose on the air intake between the TB and the MAS. It was tricking the computer into thinking it was getting a certain amount of air when it was actually getting a lot more and was too rich to run cold. Don't overlook the small stuff because it could be as simple as that.
Where's the idle at when warm? Just over 500 rpm is ideal, 700 rpm is starting to get a little high but acceptable if it solves your cold start issues.
V
vpap1
109
  • Oct 14, 2009
when it settles down it sits at 750-800. Check out the last vid .. also she may have a cam because when it sits at 750 she rumbles a bit
V
KyleEBK
173
  • Oct 14, 2009
mine does soemthin like that it kinda rumbles and goes between 700 and 950 rpms or so i dont think much of it
C
cheese_05_70
58
IL
Oct 15, 2009
  • Oct 15, 2009
Posted via Mobile Device
check your codes im assuming you took out your check engine light because i didn't see it in the video
  • brandyn200
  • Jun 20, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
