What could leak under lash?
  • Thread starter Thread starter jay90GT302
  • Start date Start date Feb 18, 2009
J
jay90GT302
  • Feb 18, 2009
What could leak under dash?
Every couple times I drive my car, I get out and see a black stain on my pants at the right shin, that looks like oil or grease. Whats leaking under my dash? Thanks in advance.
bubba-dough
1,044
Indiana
Feb 18, 2009
  • Feb 18, 2009
Could be that somebody lubed up the speedo cable. Is there mechanical aftermarket gauges? Maybe a leak there?
J
jay90GT302
  • Feb 18, 2009
There's no aftermarket gauges, the only thing I can add worth noting is i know the previous owner took the dash out to do a heater core job and that my speedo needle is constantly jumping around.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Feb 18, 2009
  • Feb 18, 2009
The brake pedal in my explorer rubs up again the inside of my right sneaker (accerator foot).
Took me like a year to figure out all my new right foot nike's were turning black on the instep.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Feb 18, 2009
  • Feb 18, 2009
Are you losing any brake fluid? I have had customers that have had their booster fill up with brake fluid leaking out the back of the master cylinder and had it drip down on their leg.
bennettracing
280
Ava, MO
Feb 19, 2009
  • Feb 19, 2009
Like the others have stated, it can only be a small number of things leaking on the left side of the dash.
1. Most likely, since you said you were having issues with your speedometer cable, is that something is malfunctioning causing transmission fluid/oil to wick up the speedometer cable into the back of the gauge cluster. Remove the instrument panel and check fitment of the cable as well as the connection at the drivers side rear end of the transmission for any mis-alignment or damage to the speedometer cable itself.
2. Mechanical gauges, which you said that you do not have installed. Anyone else with this problem will want to check these first, as a mechanical oil pressure gauge for example has a hose with pressurized oil coming into the back of the gauge. If you for sure don't have any mechanical gauges installed, don't worry about this one.
3. The brake master cylinder/booster could possibly be leaking near the pedal. Look around the base of the brake pedal while pressing the brake pedal for any fluid leakage to test, or you could also monitor your brake fluid level over time. If this were to be the case, the entire system can be removed rather easily. Disconnect the brake lines from the master cylinder (don't drip fluid on your paint!!!) and disconnect any vacuum/electrical connections from the master cylinder/brake booster. Then remove the (4) 9/16" (I think) nuts from the interior firewall near the pedal assembly, and simply pull the entire brake booster on out through the engine compartment. Replacements can be found in junkyards/ebay pretty easily.
Let me know if you have any questions.
-KB
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
J
67 mustang interior courtesy light wiring
  • JCuster
  • Jun 9, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
GypsyR
G
Drivetrain Tail Shaft bore odd shape
  • R82148V
  • Jun 12, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Mustang5L5
