what CR for a 306
  • Thread starter Thread starter aleborjas
  • Start date Start date May 12, 2006
aleborjas
610
  • May 12, 2006
hi i'm rebuilding my engine and i whant to know what is the best compression ratio for my combo to feed good my heads and headers because they are little big for my combo so what i have is 306 forged pistons, AFR 185's, 1 3/4 LT headers, 2.5 pipes til mufflers and 3" tail pipes, typhoom intake ported, 70mm TB, comp cams XE274HR, 30 pounds injectors and how many HP's can i expect from this at the wheel and at the flywheel....
jgfiveoh
102
Topeka, KS
May 12, 2006
  • May 12, 2006
10.5 to 11.0:1 thats right in the range i run. i would expect 280-300 wheels at least. good luck
aleborjas
610
  • May 12, 2006
how can i reach the 350's?
blue302stang
61
  • May 12, 2006
are you looking for 350 to the wheels or the crank, and is it a street car?
350 can be obtained N/A but will not be very streetable.
Grn92LX
Fidanza Man!
6,819
64
129
New York
May 12, 2006
  • May 12, 2006
What pistons do you have? Flat tops?
350rwhp is easily do-able but that cam isn't the right cam. Your heads and headers are nothing "too big". Keep what you have and work from there. If you have a good flat top piston and a zero deck block, just mill the heads as needed to get 10.5-11:1. Just keep in mind that if you mill a lot the manifold may not line up 100%.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
May 12, 2006
  • May 12, 2006
Those heads are "to big" for a daily driver that sees different scenarios.
For what he wants, they aren't to big, since he appears to be going for track times.
350rwhp is easy if you want to take off a couple accessories and have a high revver (more than 6k) with high compression...
350rwhp is not easy at all if you want to keep your accessories and streetabilities...
Also vacuum from the cam effects your brakes...in general, the bigger the cam, the less vaccum...
With the "flat tops"...obviously p-v clearance might be close if you are going to start cutting on those heads...
Good Luck!
aleborjas
610
  • May 12, 2006
my pistons are 4.040 they are SRP flat tops and the heads are 58cc's and i dont whant to change the cam because i whant to keep the A/C i whant to get the most HP's with what i have and some persons tells me that i have big injector and some tells me that those are ok so what do i do?i have stock rails and holley 190GPH fuel pump... should i look for 10.5 CR?
Grn92LX
Fidanza Man!
6,819
64
129
New York
May 12, 2006
  • May 12, 2006
I think you'll be happy with the combo. I'd like to see a little more gear but it'll make decent power for sure.
Not sure what changing the cam has to do with deleting your AC?
Do you know the specs on those pistons? I'm sure you'll be in the 10:1 + range. What you have is fine, just get it running and enjoy.
aleborjas
610
  • May 12, 2006
i mention the A/C and the cam because of the iddle
aleborjas
610
#10
  • May 12, 2006
  • #10
and the injectors are ok? 30's
85_SS_302_Coupe
6,945
1,598
223
Northern KY
May 12, 2006
#11
  • May 12, 2006
  • #11
I like 10-10.5 for pump gas, just in case you run into a lesser grade of gas.
aleborjas
610
#12
  • May 14, 2006
  • #12
i run 95 octanes here in my country and what about injectors? 30's?
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
Engine An engine building combo with stock Speed Density (SD) system
  • Mcmahst
  • Jan 14, 2025
Fox 5.0 Mustang Tech Jan 15, 2025
Mcmahst
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
