  • 2010 - 2014 Specific Tech
What Fluid In 2014 Mt-82 Transmission??
  • Thread starter Thread starter CoosawJack
  • Start date Start date Mar 7, 2016
CoosawJack
91
Mar 7, 2016
  • Mar 7, 2016
What fluid did the factory use in these transmissions??
People complained about "Notchy Shifting" since 2011 and mine is notchy when I first start it in 50* weather but smooths out within a few miles!!
Should I drain it and refill with "DTC" fluid and add the "XL-18" additive??
Thanks in advance!!
dusman
17
Mesa
Mar 8, 2016
  • Mar 8, 2016
I think the XL-18 just helps with transmission breakin. Many have said it heelps but only temporarily. I switched out my fluid to Redline which improved things. Others have used other brands and have had success. I would avoid second gear shifts when it's very ccold out until you drive awhile. After things warm up I find the transmission likes 3k rpm and above shifts. The 5.0 likes rpm's.
CoosawJack
91
Mar 8, 2016
  • Mar 8, 2016
Thanks "dusman".....I just looked at the owner's manual and it says 150,000 miles change for the MT-82.......sounds nuts!!
Which Redline fluid did you use??
dusman
17
Mesa
Mar 8, 2016
  • Mar 8, 2016
here is the link. I have had it since the last 12k miles. I changed out the factory stuff at around 3k.
http://www.redlineoil.com/product.aspx?pid=45&pcid=7
D
dgc333
2-1/8" feels smooth and substantial in my hands
Dec 7, 2014
28
  • Mar 8, 2016
I switched to Royal Purple SyncroMax in my 15 and it made a very noticeable improvement.
Dave
CoosawJack
91
Mar 12, 2016
  • Mar 12, 2016
Dave
Thanks Dave.......I will probably go the same way but it shifts amazingly well with the MGW shifter I just installed today!!
SpartaPerformance
2,517
61
89
Long Island NY
Mar 12, 2016
  • Mar 12, 2016
Dual Clutch Transmission Fluid, Motorcraft P/N XT-11-QDC or
equivalent meeting Ford spec. WSS-M2C200-D2. For total fluid
change add 27 mL of XL-18, MT-82 Transmission Additive
CoosawJack
91
Mar 13, 2016
  • Mar 13, 2016
I assume the factory filled my 2014 with the DTC fluid but would you know if the XL-18 was added at the factory??
T
TT5.0ca
208
  • Mar 13, 2016
It was and if it smooths out in a couple miles I'd just leave it. DTC's pretty good. Address the shifter quality issues first. If I had to recommend another fluid, I'd use Redline MTF. I tried several and this was the best combination on my last car, over the Ford QS, that came in my car. When the trans failed on its own and Ford rebuilt it, it got DTC and I just left it in. That stuff was relatively good in low temps and held up to two years of subsequent drag racing on slicks just fine.
CoosawJack
91
Mar 13, 2016
#10
  • Mar 13, 2016
  • #10
I installed the MGW shifter yesterday and.......WOW......WHAT A DIFFERENCE!! Rock solid shifts and it is a BUNCH quieter than the OEM one!!
D
DC_Dave
#11
  • Nov 4, 2020
  • #11
Wanted to resurrect this thread to help anyone else considering fluids. I tried Redline DCTF in my '12 v6 MT-82 at 55k. Seemed to shift easier/quicker, but it was grinding 2nd and 3rd gears when cold (starting at 50F or so).
Just now, at 70K I swapped fluid back to XT-11-QDC with a bottle of xl-18 (shake well!). Seems to have fixed the problem.
D
Brand New C6 Transmission Pouring fluid
  • Danielperry2003
  • Jun 17, 2025
  • Other Auto Tech
Other Auto Tech Jun 17, 2025
General karthief
SOLD [Minnesota] 2014 Ford Mustang GT | Grabber Blue | 6MT Coupe
  • Mycelus
  • Mar 20, 2023
  • S197 Mustangs For Sale (2005-14)
6K
S197 Mustangs For Sale (2005-14) Mar 27, 2023
Mycelus
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
L
Torsen T2R (M-4204-T31H), excessive play?
  • letumeternum
  • Aug 24, 2023
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 24, 2023
letumeternum
L
2013 GT 5.0 6spdm 3.73 Getrag Slip and Slide
  • MarineDeuce
  • Jan 31, 2019
2010 - 2014 Specific Tech Jan 31, 2019
MarineDeuce
