  • 1994 - 1995 Specific Tech
What Flywheel?
  • Thread starter Thread starter Code Red
  • Start date Start date Jun 7, 2006
C
Code Red
28
Austin, TX
Jun 7, 2006
  • Jun 7, 2006
There's vibration coming thru my shifter at 3200+ rpm. I think it could be my flywheel. Can I figure out what flywheel I need without taking it out first?
94gts
873
Carmel, New York
Jun 8, 2006
  • Jun 8, 2006
if you have the stock motor and balancer you need a flywheel with a 50oz imbalance. a stock replacement iron unit is $99 from mustangs unlimited
C
Code Red
28
Austin, TX
Jun 8, 2006
  • Jun 8, 2006
Yes, it's stock. Thanks. Is there any benefit in a Steel Billet vs Iron?
Killercanary
The car that set the bar.
Altoona, PA
Jun 8, 2006
  • Jun 8, 2006
It depends. If you are near stock and will remain that way there isn't much benefit. If you plan to make a lot of power and race it then the SFI rating of most billet flywheels is a plus. If you plan to make big power and run a metalic friction clutch disc then you need a billet steel flywheel as the iron will fail quickly when matched with that type of friction material. Most billet wheels are a few lbs lighter too than the iron wheels.
99FiveOh
2,051
20
99
J-Ville, FL
Jun 8, 2006
  • Jun 8, 2006
I'm just wondering how the flywheel could go bad and cause vibes. There's no weight that can shift is there? I think the imbalance is built in. Might wanna check into other possibilities.
94-302-vert
1,947
NE CT
Jun 8, 2006
  • Jun 8, 2006
unless it coule be the clutch material...
the harmonic balancer going out can and will cause this.... it is also pretty common...
99FiveOh
2,051
20
99
J-Ville, FL
Jun 8, 2006
  • Jun 8, 2006
Yeah, I'd check into those things first because unless the flywheel is coming lose, it really can't cause vibes.
Therian
The Highlander
Waterloo, Ontario
Jun 8, 2006
  • Jun 8, 2006
Driveshafts and harmonic balancers are a lot easier to check and replace than the flywheel. If the driveshaft is mis-aligned/unbalanced then you will definitely feel the vibration in the shifter. Put it in neutral and rev the engine. If you still feel it in the shifter, it's not the driveshaft. Check the balancer for rubber protruding anywhere around its edges.
If you recently had a clutch install done and the flywheel wasn't balanced correctly then you're about to have a pile of fun.
Flywheel
  • Barry
  • Mar 10, 2026
1974 - 1978 Mustang II Talk & Tech Mar 11, 2026
Barry
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
New guy- first Stang- I love it !!
  • smid333
  • Mar 22, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 23, 2026
smid333
