  • 1994 - 1995 Specific Tech
What is my problem?
  • Thread starter Thread starter RedStallion43
  • Start date Start date May 20, 2005
RedStallion43
61
Chi-Town
May 20, 2005
  • May 20, 2005
Hey, I have been having a problem with my car recently. It seems that when I cut the wheel too one side and I let the car idle, the car just dies out instead of slowly rolling. This really gets on my nerves when I have to parallel park, since you have to turn your wheel's all the way to the right or left and the car just dies, as if it wasn't getting enough gas. But with the wheels straight it seems to be ok. I guess when the wheels are turned its harder for the car to move. WHat is my problem here? I am planning on cleaning my maf sensor tommorow. But I doubt that has anything to do with it. By the way I have an auto.
S/CBlack95GT
2,018
Tampa Palms, FL
May 20, 2005
  • May 20, 2005
Raise the idle by turning the screw under the gray cap on the throttle body. Turn the screw one full round counterclockwise. Sometimes when the idle is low stalling the power steering pump will kill the engine.
RedStallion43
61
Chi-Town
May 20, 2005
  • May 20, 2005
Thanks alot. Good point. I didnt think about that. What would you say is the ideal rpm idle for our cars?
S/CBlack95GT
2,018
Tampa Palms, FL
May 20, 2005
  • May 20, 2005
I have set mine at 850-900rpms ever since I started to modify it with heads and the intake. Now I have it set around 950-1000rpms. The higher idle just seems to make it start perfectly everytime and I think it cools better at idle as well.
RedStallion43
61
Chi-Town
May 20, 2005
  • May 20, 2005
Thanks. I havent paid attention to what mine is set at right now, but my car does take a couple cranks before it starts up. Hopefully raising the idle will help it fire right up
S/CBlack95GT
2,018
Tampa Palms, FL
May 20, 2005
  • May 20, 2005
Mine idled around 650-750 when it was stock. That is just too low IMO. I think the engine sounds better when it is idling higher too.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
May 20, 2005
  • May 20, 2005
Mines idles at 750rpms I'm still pretty much stock.
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
