  • 1994 - 1995 Specific Tech
What is the best way to port an intake elbow?
  • Thread starter Thread starter badstang123
  • Start date Start date Apr 23, 2007
badstang123
397
Santa Clarita, CA
Apr 23, 2007
  • Apr 23, 2007
I want to port the intake elbow I have. I don't really need to make the openings bigger but I wanted to smooth it out inside and maybe take a little off the inside curve to smooth the flow out. What ideas do you guys have or what have you done in order to do this best. Thanks.
- Justin
AznStanger3v
2,026
Northern VA
Apr 23, 2007
  • Apr 23, 2007
use a dremel with the pen thing extension on it. if all youre doing is smoothing, thatll do the trick really well. use a fine coarse bit for it.
Bosko5.0
1,067
longwood, FL
Apr 23, 2007
  • Apr 23, 2007
what elbow ar you smoothing out???
I used a dremel with a 1/2" 180grit sanding drum and it worked very well on my trick flow 75mm elbow. then I went back and used some polishing compound to smooth it out even more. If you want pics I can get em??????
badstang123
397
Santa Clarita, CA
Apr 24, 2007
  • Apr 24, 2007
I'm doing it to the Edelbrock Elbow. I have a 70mm Edelbrock throttle body and I'm going to be running the RPM II intake manifold so it just made sense to go with the edelbrock elbow too. I just think I could help clean things up a bit better then the casting comes from Edelbrock.
Engine Cleaning Intake valves with lower intake off
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 11, 2026
limp
Replace the entire AC charge port
  • from6to8
  • Feb 22, 2025
1994 - 1995 Specific Tech Feb 22, 2025
from6to8
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
M
Broken lower intake bolts
  • Mike3
  • Aug 11, 2025
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
