5spd GT "the 5.0 owns all" Founding Member Aug 7, 2002 9,516 6 99 Arkansas Jul 30, 2004 #1 Jul 30, 2004 #1 Is it the "sheild" underneath the lower intake on the bottom side (top of intake if looking at from front of engine)...it is right underneath where the pvc hose and valve connects into the grommet...is that it?...
GT40XStang9 Thanks to Tim, I get off pretty easy. Founding Member Feb 26, 2001 25 33 89 Scotland UK Jul 30, 2004 #2 Jul 30, 2004 #2 Just to keep oil from being flung into the PVC, which is mainly designed for aerosol fumes, not actual oil.
5spd GT "the 5.0 owns all" Founding Member Aug 7, 2002 9,516 6 99 Arkansas Jul 30, 2004 #3 Jul 30, 2004 #3 Is it what I described...because if my memory serves me right...there was one on my Performer...
maverick0716 Founding Member Jan 12, 2002 3,924 0 56 Chilliwack, BC, Canada Jul 30, 2004 #4 Jul 30, 2004 #4 Yes, thats the baffle
DirtyD916 Active Member May 25, 2003 804 1 38 Norcal 916 Jul 30, 2004 #5 Jul 30, 2004 #5 should have a little rubber grommet (sp) in it.
eliaseje Founding Member Jun 16, 2002 466 0 0 Ohio Jul 30, 2004 #6 Jul 30, 2004 #6 will it hurt the engine if you take the baffle out?
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 33 129 Jul 30, 2004 #7 Jul 30, 2004 #7 the PCV will be clogged up unless your mill is super fresh. we pass enough oil to really goo stuff up. my two cents.
cevtv Founding Member Sep 15, 2002 1,113 0 37 Massachusetts Jul 30, 2004 #8 Jul 30, 2004 #8 eliaseje said: will it hurt the engine if you take the baffle out? Click to expand... Without the baffle under the intake, you will end up sucking a quart of oil every three or four days...............not good.
