Hi guys. I have a lul from 2000-2500 rpm
and there is a 100rwtq climb from 2500rpm to 3000rpm. I go from 300rwtq to 400rwtq...in 500 rpm!!
It seems a bit too radical a jump for the car and sometimes it pops. I drive this range all day and it gets on my nerves a bit. It wasn't this way right after I had the long tubes on IIRC. It was smoother with No dip in it.. So what is the problem? My tuner said he shut off the 02 sensors so it will idle right and I don't remember it being this way right AFTER I had them put on. My a/f is perfect and they cant find anything wrong and say its just the radical cam. I am getting 20mpg which is strange in a 500+HP car.
LT Headers AFR 205's
2000 rpm=310rwtq
2250 rpm=280rwtq
2500 rpm=305rwtq
3000 rpm=400rwtq
the rest of the curve its over 400rwtq until 5600rpm
Shorties AFR 205's
2000 rpm=280rwtq
2250 rpm=300rwtq
2500 rpm=325rwtq
3000 rpm=340rwtq
3750 rpm=400rwtq
the rest of the curve is above 400rwtq until 5200 rpm
Shorties Pro-Comps
2000 rpm=325rwtq
2250 rpm=340rwtq
2500 rpm=360rwtq
3000 rpm=370rwtq
4000 rpm=400rwtq
the rest of the curve is above 400rwtq until 4300rpm then straight down
It seems a bit too radical a jump for the car and sometimes it pops. I drive this range all day and it gets on my nerves a bit. It wasn't this way right after I had the long tubes on IIRC. It was smoother with No dip in it.. So what is the problem? My tuner said he shut off the 02 sensors so it will idle right and I don't remember it being this way right AFTER I had them put on. My a/f is perfect and they cant find anything wrong and say its just the radical cam. I am getting 20mpg which is strange in a 500+HP car. LT Headers AFR 205's
2000 rpm=310rwtq
2250 rpm=280rwtq
2500 rpm=305rwtq
3000 rpm=400rwtq
Shorties AFR 205's
2000 rpm=280rwtq
2250 rpm=300rwtq
2500 rpm=325rwtq
3000 rpm=340rwtq
3750 rpm=400rwtq
Shorties Pro-Comps
2000 rpm=325rwtq
2250 rpm=340rwtq
2500 rpm=360rwtq
3000 rpm=370rwtq
4000 rpm=400rwtq
... Easy Cheezee !!!
), but I couldn't find any way to data log with it. If there was a way to pull the tune from my SCT and transfer to a tweecer chip, that's something I might be interested in doing...
