I have fuel a pressure question. I have an adj FPR and a 255lph fuel pump. When I let the car sit without starting for a day or two, the car acts as if it is hard to start. I have to pump the gas pedal a little. I have an autometer fuel gauge and when I turn the key on, engine off, to prime the fuel pump the fuel pressure is only about 35psi. I turn the key several times to try and get the pressure up past 38psi (per Ford) to have an easier start. Now once she fires up the fuel pressure gauge shows 40psi. After the initial start I can just turn the key and she fires right up - no problems for the rest of the day. Now when I rev the engine the fuel pressure gauge goes down (about 38psi) and when I let off the gas it goes back up (40psi) I thought it should go up when revving the car. What's wrong?
Also, what is the proper way to adjust the fuel pressure, with the vacuum line on or off. It seems that I may need to make some adjustments. Thanks for any help. Peace
Not to sure though.
