Have you checked your vacuum? If the pressure drops when you rev it, then maybe it is not seeing the change in vacuum during acceleration. Could be a defective regulator if it is not letting you lower the pressure though.
well i found my problem, my return fuel line the chrome section that has quick disconnects was stopped up, i replaced it with another line and now i can adjust it anywhere i want it ! if you set it to 39 with the vac off what is your's showing with the vac on because mine is low say around 25 or so !
