what kind hp should i expect
stanggt00
371
baltimore md
ok guys the car is back in the hands of jpc and it should be going to the tuner thrusday ..
the car makes 446 whp as its stands
i added
60lb injectors
paxton fmic
mini-race bypass
10% od crankpulley
vortech pulley 2.95 down from the stock 3.6
what kind of power should i expect ?
also just a bit more data here :
3.60 pulley was making 7-8psi
impeller speed was 39000 rpms @ 6000 rpms
with the new pulley i should be :
2.95 pulley ???psi
impeller speed will be at 52352 rpms@ 6000rpms and/or 56715@ 6500rpms
depending on were they make the redline
i am still using the 6-rib set-up so not sure if 6500 rpms can be done with out belt slippage
